Tommey Reed’s new Clem Engine Build.
Started by TommeyLReed, April 06, 2019, 01:10:54 PM
TommeyLReed
Hello all,
My theories on the Clem engine is questionable, but my theories is something different.
I believe I came up with this design with many prototypes that did not work as plan, but each design had some small parts to this theory.
Just what is this unit?
This is based on a tornado water spout.
Tornado are heat engines as a vortex is created, temperature is lower and could reach -273k.As the temperature drops heat is pulled into the vortex to increase  rotation size.Pressure becomes negative causing a implosion effect or vacuum.
This unit is no different.
As the rotation starts, fluid is pumped upward into the drum causing it to fill due to small rim jets at the end of each tube.
Heat will start to build due to fluid friction in the pump/motor.
As the rpm's increase, centrifugal forces are generated causing pump load to decrease in pressure.
At a given speed (not known) fluid is being forced outward more then the pump can handle, causing the motor to accelerate.
In other word if the pump is moving 20gpm at 1000 rpm's and the rotating mass is pulling 30gpm, the motor will increase causing a chain reaction in the acceleration until the system blows itself apart.Control valves are need to control flow.Temperature will effect velocity of oil flow, increasing flow rate.
A vacuum is needed to prevent cavitation and air drag, this will also prevent oxygen in a flammable fuel due to temperature.
Tom.
TommeyLReed
Hello all,
This is a big build and here are more pictures.
TommeyLReed
Hi All,
Lets look at some real mathematics when things rotated.
Centrifugal force is calculated by a formula:
Force= M*V^2/R
In other words:
http://www.calctool.org/CALC/phys/newtonian/centrifugal
At a mass of water 8.33lb of fluid rotating at 2000rpm and a diameter of 4ft = 27713.6 pound of fluid force is created.
10 gallons of fluid is inside the rotating mass while it rotates at all times.
This will produce over 100,000 pounds of fluid force rotating 2000+rpm's. This mean also that the drive pump/motor will have to accelerate to keep up with all the fluid force ejecting from the rotating piston-drum.
16 pipe at 2.25IDx14in holds about 5gal.
20" drum x 4.5 hold about 5gal231cubic inch =1gal.
shylo
Hi Tom,
Nice build so far,I assume your using oil for the fluid?
Also that the fluid is being recycled?
With each cycle it will gain temperature, what prevents ignition?
artv
