Radiant power from Solid state Tesla hairpin circuit
Started by evostars, April 19, 2019, 09:55:08 AM
fejleszto
Ivo! Do you know the patent US 2004/0057255 (2004-03-25)? There are a lot of useful informations inside! Please see the text [0057], that is exactly what I was talking about! This patent mentions nothing about resonances, and uses a permanent magnet and iron core. Would be intresting to figure it out how to eliminate them (if possible).
Another intresting patent is the WO 2013/114285 (2013-01-30). Unfortunatelly, it does not cover up any important details.
The circuit from Tesla (Electrical Experimenter 1919-07 or US 609245 from 1898-08-16) what you mentioned in your last video is very fascinating, BUT! He wrote: "The essential parts of such an oscillator are: a condenser, a self-induction coil for charging the same to a high potential, a circuit controller, and a transformer which is energized by the oscillatory discharges of the condenser. There are at least three, but usually four, five or six, circuits in tune and the regulation is effected in several ways, most frequently merely by means of an adjusting screw. Under favorable conditions an efficiency as high as 85% is attainable, that is to say, that percentage of the energy supplied can be recovered in the secondary of the transformer." So, about 0.85 COP is not our goal (I've calculated 70-80% too by my experiments)! Anyway, it is strange that the coil "B" is connected to the positive(+) power supply without blocking diode, not like by your circuit parallel with "A'". But I need to read carefully the whole patent to make conclusions.
evostars
Quote from: fejleszto on January 29, 2021, 07:37:28 AM
No I do not know that patent.
Yes in that configuration of Tesla I also reached about 85 % efficiency. But that doesn't mean we can learn from it, and advance it!
My idea still is to use a dual primary coil, and with this circuit it can be done.
It really fascinates me he states there are up to 6 circuits in resonant relation!
I made another video, it show the series mosfets switching together, using a basic Radiant power circuit (2019 april),
which is the same as this tesla oscillator.
This makes it possible to create high voltage (3500V) impulses, from coil discharges.
Many think Tesla only used capacitor discharge impulses, by making use of quenched sparkgaps,
but as the article shows, he used coil discharges in his later years of research,
which benefit because
the discharge energy doesn't pass the switch (spark). If the Tesla oscillator coil discharge, was tuned properly,
it would discharge through the series resonant (low impedance=wire resistance) primary coil,
and would NOT create a spark when the commutator opened the coil circuit, that created the voltage impulse.
Thats why his relays coil kept working so long.
This new video  of me, shows the series mosfets switching:
https://youtu.be/7vfDjN2hkBg
Multiple mosfets could be used, but the bottle neck would probably be the isolated gate driver (which could be a optocoupler with glass fiber)
, and the isolated dc dc converter (which could be a battery).
I tried using 1700V mosfets, but their pinout was wrong.
The c3m1200V mosfets are on order but should be available later this year.
fejleszto
I've found an intresting wiki article: "Resonant inductive coupling", see attached!
"Power transfer: Because the Q can be very high, even when low power is fed into the transmitter coil, a relatively intense field builds up over multiple cycles, which increases the power that can be received at resonance far more power is in the oscillating field than is being fed into the coil, and the receiver coil receives a percentage of that."
How can I understand this statement?
NdaClouDzzz
Quote from: fejleszto on February 01, 2021, 12:20:29 PM
Tank circuits recycle energy!!!!!!!!!
Resonance in a parallel LC circuit: "If the frequency of the applied current is the circuit's natural resonant frequency..., resonance will occur, and a small driving current can excite large amplitude oscillating voltages and currents. In typical tuned circuits in electronic equipment the oscillations are very fast, from thousands to billions of times per second". https://en.wikipedia.org/wiki/LC_circuit
https://overunity.com/18239/the-solution/msg555085/#msg555085
https://youtu.be/e9UIZ6_4D5k
https://youtu.be/7Q0CGxOJS4I
https://youtu.be/WV6qMGd7fYc
https://youtu.be/cAVKC1myP1s
