Radiant power from Solid state Tesla hairpin circuit
Started by evostars, April 19, 2019, 09:55:08 AM
evostars
small changes
function if c1 and c2 reversed gives more power.
adding C5 over L1 makes it possible to tune the impulse (back emf inductive spike) duration. By makimg the duration slightly longer, the voltage drops a bit, and more power can be fed to the cicuit (limited by the avalanche body diode of the mosfet). L2 is reverse connected (see dot)
magpwr
Hi everyone,
I have just uploaded my latest youtube video -Solid state High voltage Radiant circuit below 20mAhttps://www.youtube.com/watch?v=yKne0ai2hRc
I am trying to reverse engineer Nelson Rocha circuit and reveal rarely seen  radiant interrupted waveform which is growing in amplitude as shown in scope which is running on 1 npn transistor only.Hence i don't take any credit since i was inspired by his video.
This radiant HV circuit can be powered by small solar cell.
Please do check the expanded youtube description.
evostars
just a small note, Im still researching.
I found the radiant circuit, is probably just one half of the system.
I made a compliment circuit, that produces positive impulses and a negative voltage offset,
by switching the L1 coil at the low side.
So I now have 2 circuits, with 2 L2 coils.
These 2 L2 coils, both have a DC offset.
one L2 is positive , the other is negative.
This way, the L2 coils, act as capacitor plates, when coupled together.
The dielectric field setup up, is then impulsed, positive and negative alternating, 180 degrees separated in phase.
This opens up a whole new set of possibilities.
I'll keep working. and when vital info is gained, I will share again on my youtube channel,
https://www.youtube.com/c/masterivo
Turbo
Hi this hairpin is a spark gap excited transmission line.
It has nodes and anti nodes and half and quarter wavelengths etc.
More can be seen here: https://youtu.be/_Vhs-ZRN_i4?t=1642
Raycathode
Quote from: Turbo on February 27, 2020, 09:18:12 AM
Brilliant thanks for sharing
Would you hapen to have a link for the Minicircuits sweep generator circuit.
Raymondo
