Radiant power from Solid state Tesla hairpin circuit
Started by evostars, April 19, 2019, 09:55:08 AM
evostars
found this in the 1919 true wireless article of Tesla. It shows the same circuit I use (solid state).
Left is a auto oscilating relais, right is the primary in series with the capacitor (bottom) these are series resonant.
inductive spike from relais enters series resonant primary,  secondary is left out, sits inside primary.
Tesla's 1897 lecture explaines the same device.
this can be run from ac also, which will give alternating polarity impulses.
This means a single L1 coil (radiant power april 2019 circuit)  can do the same, when the circuit is powered by AC (with adaptions)
I played enough with this dual primary 5 coil,
it made me realise there are 2 kimds of resonance TEM and LMD
next step is amplification of the LMD resonance, by makimg use of Tesla's Extra Coil (colorado springs notes)
evostars
Based on Nikola Tesla's Extra coil.
No dc offset needed
no negative impulse needed
L4 is the extra coil, and is still under review
bifilar pancake coils. equal copper mass
L4 has less capacity less inductance, bigger diameter wire leas windings than L3.
this steps it up
synchro1
@Evostars,
Illuminating underwater bulbs with your circuit may add safety to pool lighting, right? You could package and market a successful product.
