Four rod magnets and two one way bearings = free energy???
Started by magnetman12003, May 06, 2019, 08:18:28 PM
gyulasun
Quote from: magnetman12003 on May 13, 2019, 06:39:12 PM
Here is a photo of what I was talking about.  Might need resized by someone?
Hi Tom,
Thanks for the picture. You show an interesting setup and I think you hope that the almost floating heavy top magnets will insure the tangential force needed for the arms to move clockwise.
Well I think that the two arms will receive a one time pushing force in the moment you drop the two magnets into the tilted PVC pipes and the arms will move together for a certain time till friction stops them.
It is okay that the two top magnets would continually repel the bottom magnets but this force will be a resting, static force.  The comparison to a bended bow is still valid like in your first set up.
Of course I may be wrong and if you are convinced this setup would operate continuously, then only a replication can show reality.
Gyula
magnetman12003
Quote from: gyulasun on May 14, 2019, 09:16:49 AM
Hi Tom,
I have already started the build and it should be quite heavy when completed.  Plan to use 4 heavy rod magnets at 45 degree on top arms and 4 vertical heavy rod magnets on the bottom arms.   All my work is posted as open source information so anyone interested can replicate it.  I am using ceramic skate bearings for the wheels supporting
my cylinder and other bearings that have very little friction.  I will show you a side photo of where I am at presently
I have the outside of the drum covered in V shaped bearing balls that I had another idea for prior to this.
I am waiting on a longer 8 mm center shaft now.  Tom
Gyula
skywatcher
It's always the same error in reasoning.   ::)
Any construction involving only permanent magnets and other passive components will only move until the equilibrium of forces is reached, and then it will stop.
magnetman12003
Quote from: skywatcher on May 14, 2019, 06:06:31 PM
[/quote
Worth trying anyhow with four heavy magnets free to bear down at 45 degrees on lower magnets.
Something has to move.  Anyways here is a photo showing the four magnets I will put into 45 degree pipes where they will be free to slide.  Might even try 22.5 degree also.  I am using a top circular plate instead of arm which makes things easier.  My other 4 magnets are secured inside the cylinder.   Tom
magnetman12003
Quote from: magnetman12003 on May 14, 2019, 06:29:52 PM
[/quote
