Physicist needed, will this self-loop?
Started by ARMCORTEX, May 09, 2019, 06:01:38 AM
ARMCORTEX
I am now accepting woodbuilder candidates.
Work you fools! Work harder!
Wear a helmet.
citfta
Why don't you just build it.  Then you will have your answer.  Someone with your great intellect should have no problem turning your drawing into a working device.
ARMCORTEX
Quote from: citfta on August 28, 2019, 05:33:03 PM
I think its better to waste other people's ressources before a physicist models it for me, in the way I am satisfied with.
But even then, I may suspect foul play.
But its good, I can see you are curious as well now that it sinks in. You are not really sure anymore are you ?
https://www.youtube.com/watch?v=vTuaXOFbLjs
8 of these, as symmetrical squeeze forward units, suspended in the air as drivers. I wish to investigate mass lag with impulse load such as an incoming pendulum bob, wich will be slower.
Flywheels have an infinite rate of transfer of energy, this is interresting.
Wichever method recharges faster the flywheel after a spontaneous load, direct motor connection or pulse magnets, to maintain perfect equilibrium with motions.
conradelektro
Your design shows your high intelligence and your very inventive mind.
The design will turn all by itself, faster and faster, till it self-destructs. Therefore you should think about a break which keeps the turning of the device below a certain speed.
You have found the solution for the energy needs of mankind.
I wonder if you will give it away for free?
ARMCORTEX
Conradeleckro, you are too kind.
But I fear these excessively optimistic comments just as I fear excessively negative comments, untill we know more. Ok, maybe I prefer the positive ones  ;)
This is because such a machine is a big endeavour, even for a professional fab shop.
This device is an interresting museum machine either way, it looks like a choo choo train.
Certainly there will be things to break it ;) That problem you speak of would be a nice one to solve right?  ;) It all depends on launch condition, this is a "computer launch" mechanism, once this happens it likes to stick to its resonance and almost auto-syncs.
If I will keep it? I am not keeping any more info at this moment... Yes it is mine, I do intend to patent it since I am the inventor of it, in part, the co-inventor is another youtuber.
