Physicist needed, will this self-loop?
Started by ARMCORTEX, May 09, 2019, 06:01:38 AM
ARMCORTEX
https://overunity.com/4672/accelerating-forces/msg96915/#msg96915
Listen to David Lowrance, he is special.
It seems, that there may be more to this than I thought.
Now, do I even need a Physicist anymore if the orbital slingshot effect applies? This is basically a titan with a hammer smacking my weight at the optimal time of acceleration, should I arrange this with my drive scheme.
Of course the next turn is coming... But all those pair of pressures are reflected into rotation during the whole swing when it is in resonance, but at what % is the question, it seems to have the ability to push an elephant but not an elephant + 100 pounds... This smells powerful, but now I am losing centrifugal force should this be re-applied at a different angle under pulse, perhaps for a small time? Lol... No I think I need a physicist... This is truely a marvel on engineering.
I have created the mother of all mindfuck exeptions to newtonian physics. Somebody find a solution to this mindbender I beg of you.
I think I deserve my 10,000$, I will share 75% of this to the person who solves this.
conradelektro
Quote from: ARMCORTEX on September 01, 2019, 03:19:01 PM
Again, your superior intelligence is showing, long live the new Newton!
Why do you need a physicist, you did it all by yourself?
What do you think a physicist will tell you?
Greetings, Conard
ARMCORTEX
Ok thank you Conrad, but its not necessary.
I feel like talking seriously now.
I know you are sad that I cant calculate it and show it works and you feel like making it but dont have enough money so you just troll instead.
These are the moments when you feel bad about not knowing more about differential equations and mathlab.
I also have a feeling that the theory of slingshot will be hard to model, since this is very "obscure" science, the degree at wich the centrifugal and centripetal are actually deflected to reach "out of balance" state wich is beneficial, I believe the rate of change of speed must very high, not smooth, with very steep derivative at that moment.
A model allows you to predict what will happen, its true for this device just as its true for a normal servo motor.
The power of these MIT kids is unreal, they can do this in a weeks work maybe. I'm such a bad scientist...
ARMCORTEX
https://www.youtube.com/watch?v=_3sHn6LOu9A
The quest has ended, overunity can be provided.
Either by magnetic doudble sided pulse gun system, or with flywheel double squeeze method, force amplification will be available.
Should we be able to keep the weights synchronous and follow a constant frequency, Horsepowers can be harvested by simply pulsing a multitude of unbalanced weights if a stable and fast frequency we can optimize.
Spread across time such as our energy input is constant, but given as impulses of kinetic energy, wich = constant enery expenditure, but I believe it will be worth it.
