science and prediction
Started by lancaIV, May 20, 2019, 06:01:34 AM
1,5°C to 2°C to   ?  ° C  ambiental temperature increase in XYZ years, decades, centuries
Temperature and volume related mathematical question :
when an Otto-ic-(gasoline/petrol)combustion motor has as car wheels drive engine an average 6 liter petrol/100
Km consume and the average Air-number (Lambda-value) is 14,
how many Kg total gas the motor converts during 100 Km drive and with which motor efficiency per kg gas  ?
Assuming 6 liter Petrol x 0,78 lt/Kg and lamda= 14  the car exhausts/emitts
        ~ 65,5 Kg gas - mix / 100 km
        ~ ?  liter gas - mix   / 100 Km
        ~ ?  liter liquid -mix /  100 km
These 65,5 Kg/100 km   leaves with which average temperature the exhaust and warm up how many cbm ambiental  air volume over 1,5/2/3 and more ° Celsius temperature. ?
the main function from ic motors : chemistry converter, by-function :  motive energy delivery
If a 6 Liter/100 Km Petrol consume Otto-ic-motor is calculated with average 20% efficiency performance,
which engine compression conversion efficiency has to be calculated with 65,5 Kg/100 Km consume,
for real efficiency comparision
COMPRESSED AIR ENGINE :                       DIESEL/OTTO- INTERNAL/EXTERNAL COMBUSTION GAS ENGINE
Not CO2- taxation, a geral Lambda-taxation for all combustion engines is the geral solution against air over-heating !
Also hydrogen--engines emitts heat and influence the natural average temperature. !
Each force converter emitts heat, work= conversion with co-/ad-haesion friction energy
CO2 is relatively not dangerous and we can expect  500 ppm in 3, 600 ppm and more in  5 decades: without human living behaviour change ! Independant from energy taxation high. !
New electric field and static combustion methods as solution. :
https://www.imperial.ac.uk/news/169087/lasers-could-rapidly-make-materials-hotter/
https://newatlas.com/gold-melt-room-temperature/57327/
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.n-tv.de%2Fwissen%2FSteigender-Meeresspiegel-bedroht-Grossstaedte-article21294905.html
Enough time for the next generations to leave these regions. ! Giving up risc zones. !
Without financial compensation  !
Children are liable for the work of their ancestors. ! Evil heritage. ! Not the estatal society in geral  !
4 mm/p. a.  in 25 year      ~ average  100 mm= 10 cm=  0, 1 mtr.  sea-level increase
4 mm/p. a.  in 100 years  ~ average 400 mm = 40 cm = 0,4 mtr.  sea- level increase
Living each day with high water level changes : "Tidenhub" : up to 14 mtrs. =
        14000 mm  in 12 hours
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.wattenpeter.de%2Fwatt-und-mehr%2Febbe-und-flut%2F
          4 mm in 1year = 365 days = 730 " 12 hours"days = or 4 mm/730 = 0,0055 mm in 12 hours
        14000,0000 ( fourtheen thousand,virgula/komma zero)       mm
        0,0055 ( zero,virgula/komma zero zero fivefive)       mm
    14000 divided by 0,0055
    ~ 2 million five hundred fourthy five thousand and four hundred fifthy four times
      the comparison from " scientist fear propaganda " and real life max/min happening ratio
Compressed air engine efficiency   versus internal/external combustion engine
https://en.m.wikipedia.org/wiki/Angelo_Di_Pietro_(inventor).    UP TO 94,5% EFFICIENCY
versus
https://peswiki.com/directory:gun-engine.                                      UP TO 95% EFFICIENCY
Not/ understanding science and methodology  :
I wrote the Text https://overunity.com/13629/new-tech/msg539215/#new #37
in german language, somebody closed the tread ( I not !  and I did not get a negative comment about it  !))
How a not german educated person/reader has to understand this article content if translated by " automatic sense-less Google machine"- technique. :
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Foverunity.com%2F13629%2Fnew-tech%2Fmsg539215%2F%23new
Word and meaning difference  :
german " keulen" : why Google translator "Pigs" ? AGENT PROVOCATEUR. ? ;D Right : to cull, to clube
"VOLKES STIMME" = NOT : PEOPLE VOTE BUT "THE CONSTITUTIONAL PREVIEW"
"HOCHVERRAT" = HIGH DEFINITELY  :P Right : high treason ,from justice court view
GENICKBRUCH = A GENIUS BREAK  :o Right : broken neck
(Al)   FEDERAL REPUBLIC OF GERMANY
  8) AI : artificial intelligence instead Al Bundy ( instead "Bundes") Republik = A. I. - CENSORING  ;D
And many more structural errors in language meaning Syntax. !
         Neuronal synthetic machines do not have the ability for " Wortspiel ":"clever wordplay" translations
Do not trust actually " machine tool translation" : do your own mother-/father language article and then let it translated by "dolmetching synthetic machines": read now this by " machine intelligence" generated content and remark how mad the probably serious texte could become !
Sintony  ! Less Catatonia !
Life and the Learning
Hello HoloProfessor, hello HoloArchitect, hello HoloEngineer, hello HoloUniversitarians,hello HoloParlamentarians
Virtual cyberworld- humanoids in Eprom-kind as " future worker" : for assistance or 100% replacement
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fm.spiegel.de%2Flebenundlernen%2Funi%2Funiversitaet-hawaii-hologramm-professor-haelt-vorlesung-a-1283821.html
What is science  ? From latin : scire ( infinitive) , german : wissen( infinitive , Nomen : das Wissen, Wissenschaft),
anglo-saxonic/english : to know( infinitive,Nomen : knowledge)
Question :
What is the earth average temperature. ?
https://www.google.com/search?q=earth+average+temperature&ie=utf-8&oe=utf-8&client=firefox-b-m
A.  the average earth surface temperature is approximaly 14° Celsius
B.  the average temperature on earth is 61° Fahrenheit ( 16° Celsius)
Result : 1 question and two different answers. !
                2 DEGREES CELSIUS DIFFERENT
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.bmwi.de%2FRedaktion%2FDE%2FArtikel%2FIndustrie%2Fklimaschutz-abkommen-von-paris.html
        THE PARIS AGREEMENT HAS THREE OBJECTIVES
THE ESTATES SET THEMSELVES THE GLOBAL GOAL OF LIMITING GLOBAL WARMING TO " WELL BELOW"TWO DEGREES CELSIUS COMPARED TO THE PRE-INDUSTRIAL ERA, WITH EFFORTS TO LIMIT IT TO 1,5 DEGREES CELSIUS. !
Temperature and variance( day/night) :
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FErdatmosph%25C3%25A4re
Atmos
Tropos
Strato
Meso
Average temperature for each sphere pre-industrial up to actual average temperature. ?
Several spheres density and chemical composition change from pre-industrial up to actual density. ?
What is temperature : the indicator for kinetic energy movement    https://en.m.wikipedia.org/wiki/Temperature
               THE PHYSICAL UNIT FOR KINETIC ENERGY : JOULE ( ancient : CALORIE, calor = Waerme= heat )
https://www.google.com/search?q=unit+for+kinetic+energy&ie=utf-8&oe=utf-8&client=firefox-b-m
Each energetical output is measured in Joule and convertable to
https://www.rapidtables.com/convert/electric/Joule_to_Watt.html
Global temperature limiting does not mean only GHG- output limiting, but total Joule( or Watt)-emission limiting. !
https://en.m.wikipedia.org/wiki/2000-watt_society.      VISION OR GLOBAL COMMAND ?
There is never the existence from " one clean Joule" or " one dirty Joule" :  Joule is Joule,  each counts. !
Wind-Joule, Solar-Joule, Fossil-Joule, TPU-Joule, Mo-Gen-Joule,.......: physically no difference  !
Physik ist die Ueber-Wissenschaft, in neutraler Position,.Diese bestimmt nicht die Anwendung.
Dafuer stehen die Oekonomie, und Oekologie sowie Ethik mit den vorgegebenen Grundsaetzen zur Verfuegung.
