Thanks to ALL for your help!!
The solution !!!!
Started by efusystem, June 10, 2019, 11:48:24 AM
NdaClouDzzz
Quote from: tomd on November 08, 2020, 04:22:28 AM
Why do we need to pump electrons from ground? The tank circuit, which the primary coil is a part of, should generate sufficient magnetism to power the secondary coil and any load thereof as demonstrated in this video - https://youtu.be/kQdcwDCBoNY.
As I understand it, in a true free energy device of this nature, the load is separated from the rest of the circuit using capacitors and a full wave bridge rectifier.
Energy Propagation https://youtu.be/kQdcwDCBoNY
Tortuga0303 ( Armagdn03 on the forums) tells you how to reproduce the effect: https://www.energeticforum.com/forum/energetic-forum-discussion/renewable-energy/14511-energy-propagation
Used by Tortuga to create his demo: https://www.allaboutcircuits.com/textbook/alternating-current/chpt-6/parallel-tank-circuit-resonance/
OUR member NerzhDishual also reproduced Tortuga: ( Reply# 54 ) https://www.overunityresearch.com/index.php?topic=2309.msg35940#msg35940
Parallel Resonance Circuit https://www.electronics-tutorials.ws/accircuits/parallel-resonance.html
Power Factor Correction https://www.electronics-tutorials.ws/accircuits/power-factor-correction.html
Power Triangle and Power Factor https://www.electronics-tutorials.ws/accircuits/power-triangle.html
NOTE: More inductance = more magnetic field! Paul Babcock's "magnetic energy secrets" is highly recommended watching!
NdaClouDzzz
Melnichenko's resonance https://translate.google.com/translate?sl=auto&tl=en&u=https://www.skif.biz/index.php?name%3DPages%26op%3Dpage%26pid%3D2
                                               "the capacitance must correspond to the inductance"
Melnichenko's patents
https://3jhehcks7fktlxe2qny3nxcxpi--www-skif-biz.translate.goog/index.php?name=Pages&op=page&pid=11
NdaClouDzzz
What could be a companion video to the first part of Tortuga's ENERGY PROPAGATION video:
A Light Bulb Mystery- Electric Resistance // Homemade Science with Bruce Yeany https://youtu.be/teHFi47qCEA
Energy Propagation(Tortuga video) https://youtu.be/kQdcwDCBoNY
