The solution !!!!
Started by efusystem, June 10, 2019, 11:48:24 AM
NdaClouDzzz
I forget that conspiracy is a bad word to some. I don't use it or intend it in a bad way. I mean it more as suspicious ponderings, questioning the underlying nature of what we are seeing on the surface; and our conclusions are not always able to be supported by objective evidence. To me, conspiracy just means hidden truth. I try to avoid conspiracies these days, or at least I try to limit my self to very little, as I've been there done that and I tend to lose myself when venturing down the endless rabbit hole. So, no offense intended.
cheers.....🎃🎃🎃🎃🎃.....
stivep
Thank You my friend
I do appreciate your comment
Wesley
NdaClouDzzz
www.feprinciples.wordpress.com
Janos Vajda ( since 2010 R.I.P. ) with study  : violation of the energy thesis in wave fields
HU9601424 hungarian patent application
+ Alfred W. Huebler : digital quantum nano tubes array a. as battery b. as amplifier
NdaClouDzzz
Huzzah! Thank you, lanca!
At least I know I'm not TOTALLY imagining things!
"My take: Two equal radio frequencies going in opposite sides of a coil and colliding in the middle should not only lower (reduce) the frequency, but also increase the amplitude of the wave, thus increasing the power"  https://overunity.com/18653/ac-voltage-from-single-magnetic-pole/msg552154/#msg552154
"When two waves with identical polarization, frequency, phase and amplitude propagate in the same direction and meet (and merge) in free space, then their amplitudes will add together and the amplitude of the resultant wave will be double that of a single input wave. This physical phenomenon is called superposition or interference of the waves, when (under the above conditions) the amplitude of the resultant wave is calculated by simply adding together the amplitudes of the incoming waves"  https://feprinciples.wordpress.com/how-to-gain-free-energy-from-wave-fields-simplified-explanation/
