Magnet motor idea hopefully solved
Started by Low-Q, June 14, 2019, 10:59:32 AM
gotoluc
Hi Vidar,
I can't believe no one has commented since you started showing your building progress, which is awesome by the way and so is your design.
I'm sure everyone is looking forward in seeing the results of this most interesting idea.
I assume you have to tune each link because of small printing imperfections?
Thanks for sharing
Luc
tinman
Quote from: gotoluc on July 20, 2019, 01:28:46 PM
Hi Vidar,
Thanks for sharing
Luc
Well Luc,i cant believe i missed this project either.
What a huge project.
Will be keeping an eye on this one for sure.
Good job Vidar  ;)
Brad
Low-Q
Thaks Luc and Brad!
Yes, I think it is an interesting design. I posted a less detailed idea on an alternative energy source website a while ago. Engineers and inventors had never seen this idea before. Funny to know that no one, or at least possibly very few people has ever thinked about this approach before. They hadn't seen this before, or even thinked about anything similar :)
I have been struggeling with tweaking, when I finally realized that the printer nozzle is 0.4, not 0.5...
I must start over with all pulleys, links, and end caps. Did some improvements in the design so it doesn't jump off so easily. Every part of the belt is internally repelling. This force the belt radially to jump off the pulleys (which has too small teeth).
Narrower pulley, longer teeths,and wider end caps will secure the belt and the magnets much better.
The temp sensor sometimes glitches, so filament got burned. Replaced the nozzle three times just today...
I'll keep going anyways :)
Vidar
Low-Q
Printing gears for the pulleys. These will follow a large gear so the belt can keep its polarity still.
Vidar
Low-Q
New better parts on its way. This will secure the belt much better, and makes it possible to put glue into the endcaps to secure the magnets.
Vidar
