low cost passive foam-home construction
Started by lancaIV, June 27, 2019, 07:20:27 PM
A heat pump moves by mechanical work from. place A to place B an heat volume, termed f.e. in BTU
We have to spent 1 unit energy to move in average 2,5 units energy.( by conventional air-air heat pumps)
But because this 1 work unit is often electric we have to spend 1,8- 3 units( sources-mix- dependent)   primary energy to move  in average 2,5 units
Take two boxes : one side cold and one side warm. : middle temperature  ? total kcal value. ?
Take two boxes: one -/one +  and connect them with passive heat-exchanger : middle temperature ? total kcal value ?
Take two boxes : one-/one + and connect them with a thermodynamic Carnot cycle equipment:
           you have to invest work energy units for this now active/forced process
YOU change the two boxes  ,now system,middle temperature energetic
And by the above calcuation : 2,5 units + 1,8-3 units= 4,3-5,5  units are the energetic invest for 2,5 units movement
https://de.m.wikipedia.org/wiki/W%C3%A4rmepumpe
              2,5/4,3 and 2,5/5,5 : the result is called  mathematical Quotient in german thermo-physics
                              GUETEZIFFER, shortly "ETA" and defines the " Carnot-factor"
             The emitted heat (kcal,BTU,KJ) is not and nevermore technical restoreable( thermical Pandora box)
                by actual conventional physics and her( female) CONSTITUTION
                https://en.m.wikipedia.org/wiki/Thermodynamics
              But process deceleration is possible :  but Carnot-factor ever maximal < 1 ~ 0,9999999......... PERIODE
sm0ky2
If we use an air condition style compressed gas system
There are other ways.
Solar radiation can operate fluid-based heat pumps
There are also peltier/seebeck thermoelectric generators
which act as a heat pump between two places
and generate energy while doing it.
not that I'm saying it would be an efficient use of a TEG
But that such things are possible, to utilize the excess heat
of ambient sources to heat our homes.
And by the same utility, our hot homes can be cooled by less hot
ambient sources.
ramset
SmOky2
:) hope this rings your bell and finds you well !
here some news on AeroGel and scrap tires  [i had posted in the wrong topic... thx to Lanca for link]
https://news.nus.edu.sg/research/worlds-first-aerogels-made-scrap-rubber-tyres ////below are other things on Aerogel from Lanca
+ Schukey ( R.I.P.) https://www.thermodyna.com/start.html cryodynamic cascade down to -180 degrees Celsius chamber and crushing shock (ultra sonic )
Aerogel as part from vacuum insulation panels
https://www.habiter-autrement.org/08.minimaliste/contributions-08/minimalhaus.pdf the last : CUBUS-der fertige Raum ,Manuela Skorka
and
http://mtbest.net/household_efficiency.pdf
from bio-waste,rice husc,also silicon based aerogel production possible
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=11&ND=3&adjacent=true&locale=en_EP&FT=D&date=19800729&CC=US&NR=4214920A&KC=A
Thanks Grandma
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.bento.de%2Ffuture%2Fmieten-leopold-tomaschek-hat-sich-ein-tiny-house-gebaut-a-00000000-0003-0001-0000-000002598898
11000 Euros for 15 sqm living area is for me not idealistic !
wood-home / wood-home comparison http://www.butlerprojects.com/other/grandcabin/index.htm
But it is an article about :
IDEA
D.I.Y. (probably with help of others)
1. thinking
2. avaliation
3. planning
4. realizing
5. living
