KUNEL device
Started by nix85, July 06, 2019, 01:10:35 AM
Quote from: WhatIsIt on July 06, 2019, 05:32:32 AM
From my experience, using magnet is like using spring.
How much power you push in it , it will return same or less.
So , magnet only will not hold the water.
Something is missing.
A Mister WilliamThompson,  also known  as Lord Kelvin, would partially agree to your mind .
But he defined capacitor/spring analogon estate.
What differs a permanent magnet from a capacitor( wider from electret,magnetret)
WhatIsIt
Quote from: lancaIV on July 06, 2019, 05:29:05 AM
To understand the internal process from the Kunel static transformer study his rotative analog device :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=11&ND=3&adjacent=true&locale=en_EP&FT=D&date=19820819&CC=DE&NR=3101918A1&KC=A1#
look in " mosaics" for the energy flow diagramm and the description to this
Thanks lancaIV,
At first I was thinking that you and your mind are separate entities.
But now, I realized that you are pointing to right things.
Like our small Wikipedia.
I started to read your links and most of the time you are pointing to right direction.
So, it is useful to have you around.
Thanks!
WhatIsIt
LancaIV,
you are good at finding facts!
Can you find if someone get even close to solution of Kundel patent.
Can you do this for me? And for Nix85?
Please. No joke!
nix85
Don't forget about Silverhealtheu.
From Patrick J. Kelly's PDF
"Silverhealtheu. One of the EVGRAY yahoo forum members whose ID is
'silverhealtheu' has described a simple device which appears to be not unlike
the Richard Willis generator above.
The device consists of an iron bar one inch (25 mm) in diameter and one foot
(300 mm) long. At one end, there is a stack of five neodymium magnets and at
the opposite end, a single neodymium magnet. At the end with the five
magnets, there is a coil of wire which is strongly pulsed by a drive circuit. Down
the length of the bar, a series of pick-up coils are positioned. Each of these coils
picks up the same level of power that is fed to the pulsing coil and the
combined output is said to exceed the input power."
Interesting that pick-up coils are the same size as interupter.
It probably does not have to be that way.
gyulasun
Hi,
I agree with you, that is a general conclusion for many magnetic setups, I have also found less output than input.
However, there can be some other setups where that is not the case.
Member Floor has been showing setups you may find interesting :
https://overunity.com/18137/newtons-magnets/msg530970/#msg530970
Gyula
