A-King 21 - build discussion /investigation
Started by ramset, July 15, 2019, 09:13:34 PM
r2fpl
a.king21 - Have you seen any other Kapanadze's films that have not been published on the internet?
Do you still have contact with Kapanadze?
NdaClouDzzz
Quote from: Void on July 17, 2019, 10:35:46 PM
Hi a.king. I understand the concept of electrostatic induction, and I have experimented with it
using an earth ground to one capacitor plate, and only could ever get flea power out of such an arrangement
even when charging the other capacitor plate to at least 8 kV on a 0.1 uF HV cap at around 20 kHz. If there is a
way to make that work with reasonably high output power, I couldn't find it anyway. Maybe I am not quite enough
of a moron to get it. :)
What exactly did you do to measure this "flea power"?
A 0.1 uF cap isn't anywhere close to the capacitance that you need to get "reasonably high output power"! To get something usable from 0.1 uF you need a much higher frequency than 20 kHz and then discharge it to earth-ground through an appropriately sized step-down transformer. Just imagine the shock you get when you touch a doorknob. Now replace the doorknob with a transformer where one end of the primary is earth-grounded and you touch the other end of the primary. The spark jumps from your finger to the primary and moves through the primary going to earth ground and the resulting magnetic field generated in the primary induces current/voltage in the secondary giving you POWER! à la Don Smith's EES!
NOTE: Don Smith's AMBIENT ENERGY GENERATOR is merely the energy HARVESTING/PUMPING phase, NOT the POWER phase; that is, it does the same thing that your body does prior to you touching the doorknob!
The power of those accumulated electrons: https://youtu.be/b89x8CAS6xU   https://youtu.be/T6VKxmUPb3g
Device harnessing the power of the shock: https://youtu.be/H16CvNo5kBY
Charging by Induction: https://openpress.usask.ca/physics155/chapter/1-2-conductors-insulators-and-charging-by-induction/
r2fpl
Accumulation of electrostatic charge even for 1 Watt is very high.
The Winhmurst or Van der Graaf machines are pure electrostatics and the conversion to electricity is very small.
The accumulation of charges is impressive only for the person affected by the HV impulse, but not for the power of an ordinary lamp.
It all comes down to an impulse, but the impulse doesn't have to have the same meaning as a hammer.
Don Smith never showed a real device. All because these are only his scientific works with no final effects.
He thought others would do it and then he would be happy.
NdaClouDzzz
Is r2fpl Void's alter ego?
The diversion tactics are lame!
More and more are doing the experiments and learning the truth!  ;)
r2fpl
Quote from: NdaClouDzzz on May 10, 2021, 03:32:24 AM
Don't confuse me with others because I'm not like them.
I have some experience with what I write and these are my opinions. Of course, you can disagree. That's what we're here for.
