A-King 21 - build discussion /investigation
Started by ramset, July 15, 2019, 09:13:34 PM
AlienGrey
Quote from: Void on July 16, 2019, 12:39:35 PM
Hi a.king. Any coil-based or other device that produces high voltage spikes or even
clean HV sinewaves typically produces a lot of problematic emissions which can produce major havoc
with digital based equipment, which includes most electronics and equipment these days. :)
That is interesting about you appearing to see a difference in performance between day and night,
but that is not necessarily a verification of Don Smith, but it might relate to something Don Smith has
talked about. From what I recall, the 'Don Smith Effect' document was not a document created by Don Smith, but
by a forum member who said he created that document based on his understanding of some things
Don Smith has said, and I don't recall Don Smith himself ever presenting something exactly like what is depicted in that
Don Smith Effect document, but he may have somewhere that I didn't run across in my investigations of Don Smith's
material and his old forum postings in the past.
I have experimented with that so-called Don Smith Effect a fair bit, and could not replicate such an effect,
and I am not sure how the circuit posted above relates to this claimed effect, but I will take a closer look when I have a chance.
My results with testing the Don Smith Effect as it was depicted and described in the document were
negative so far. That doesn't mean that there isn't some very important detail or details missing there however, as may possibly
be the case with various other Don Smith devices. It is possible, as Don Smith pointed out clearly in one video made of
him, that the exact geographical location is very important if a person wants to have a chance of replicating a Don Smith setup
which relies on an earth ground to produce the COP > 1 effect.
Hi mr Void So what did you use for a SG and generate the ramp timing ??
Quote from: ramset on July 16, 2019, 12:19:01 PM
Racks bite ....
A pain in the pants...
I hope things stay extra nice......
Plenty here would love to see you play that UKE
Yep.
But it's all done and dusted now, officially back on the road after two full days of work and no help.
AlienGrey
Quote from: a.king21 on July 16, 2019, 11:42:39 AM
TK,  as I said in a previous post on another thread, there are enough brains here to sort this stuff out if we co-operate. I for one DO appreciate your building ability and Yes I do think the earth engine is a scam to get investors. But I also think that Rick Friedrich is a huge asset if we can all co-operate and start building.
The Uke device works better in the day than at night as I have proved to myself thereby verifying Don Smith.
ALso there is a way to loop it but it is only the first of 2 stages.  I would really appreciate a phase lock loop Slayer coil schematic. Or even better a crystal controlled Slayer circuit. Slayer because it is the least harmful of the Tesla type coils (unless you know of one with even less emissions.)
A line output transmuglifier LOPT? ;D
Oh, I knew I had a video somewhere. Just took a while to find it.
https://www.youtube.com/watch?v=3Cv4XF4FV6w
Be sure to read the Description.
ramset
Yeash a dreaded job and can be very dangerous to do
especially on flat ground or should I say without a
Proffessional car lift
Makes it much harder
glad you're safely through that
Thanks Grandma
