A-King 21 - build discussion /investigation
Started by ramset, July 15, 2019, 09:13:34 PM
There are at least a couple of ways to use a PLL in this application. One would be to emulate crystal frequency lock-in so the device would only operate at that single frequency. I don't know what use that would be, as resonance frequency of a helical resonator depends rather strongly on the environment. So a better use of the PLL would be to keep the system in resonance by changing frequency as required. But the plain old Slayer/Kacher circuit already does this!
As we have noted though, the base drive of the Slayer circuit is relatively sinusoidal and so does not result in the maximum dv/dt that one might like. I've considered putting in a Schmitt trigger between the Slayer feedback connection and the transistor base. Also a carefully chosen mosfet would probably be good there. So pretty soon we are evolving towards a real SSTC....
But I think a real Tesla disruptive discharge system is probably to be avoided here. Because you will get this kind of stuff happening from all metal in the vicinity: https://www.youtube.com/watch?v=aIZClhoU2Xk
Of course Master Ivo's DD system probably won't do that.  ;)
AlienGrey
Quote from: TinselKoala on July 16, 2019, 01:25:00 PM
No you mean Nelsons device he shared with Master ivo notice the way the circuit works as well below zero. and the bifilar caduceus /pancake wind of the bemf collect coil.
Back to you Mr Tinsel K
Oh, no, no no,  I wouldn't dream of getting in between you, Rocha and Master Ivo. So y'all just go right on ahead, and when you get OU.... let me know.
Of course I mean this kind of OU : Joules in < Joules out.  Your mileage may vary.    8)
a.king21
My beef with the Slayer is that you get too much parasitic capacitance. I suppose the way to use it is to keep a distance from it or maybe isolate it in a faraday cage. That is why I thought that maybe pll ing it or getting a crystal circuit may be a reasonable compromise, (unless you are transmitting and receiving).
Well that's what you get with the E-field emitters. High frequency (in the Benitez-Tesla sense, single digit MHz ranges) + high voltage = capacitive coupling like crazy.
So my solution has been to go to lower frequency mostly EM coupling. Or, dare I mention it, hybrid devices with optimized geometry of transmitter-receiver pairs.
Here's me with a EM receiver antenna wrapped around my head, with an incandescent bulb powered wirelessly.
Try that with a Slayer, or even RF's gatedriver coil setup. Or maybe you shouldn't, after all.
