Success and loss
Started by tinman, July 19, 2019, 08:03:33 AM
MoFo
Now TrollMan, I hear you have at your disposal a Group of expert Scientists, gurus, experts in their field, been doing this all their lives, most of them working for Mark Goldes at one point in time?
How true is this, and are they really at 'your' disposal?
MoFo
Don't want to answer any more pop quizzes TrollMan, afraid I am about to destroy your community reputation further than you already have?
Both you and Mr Koala seem to be extremely afraid of this 'Chris' you both refer to, after I am done it'll be 'Christian'.
My name is Christian Rhodes and I am not afraid to expose filthy liars and bullshit artists!
More TrollMan Lies: September 17, 2015 https://overunity.com/16030/tinmans-coil-shorting-circuit/msg461016/#msg461016
MoFo
Why did you remove your only real success TrollMan?
Then start lying about it?
Where did I get that image from? I wonder?
tinman
Quote from: MoFo on July 21, 2019, 05:14:17 PM
It would be more accurate to say that we help each other out.
tinman
Quote from: MoFo on July 21, 2019, 10:14:20 PM
Ah,well talking about filthy liar's--
You take the given measurements i provided for this machine,V1 of the RT--
https://www.youtube.com/watch?v=szpJ97M58G4
--and then you post those measurements along side this smaller machine,which was version 3 of the RT--
https://www.youtube.com/watch?v=xmJr4_gHygo
So yea,talk about exposing filthy liars  ::)
QuoteBoth you and Mr Koala seem to be extremely afraid of this 'Chris' you both refer to, after I am done it'll be 'Christian'.
We're not afraid of him other than he keeps botching everyone's hard work up. So he causes damage when he truly stuff's things up when it come's o other's work. He tried to promote his bucking coil bullshit by using other's successes.
QuoteWhy did you remove your only real success TrollMan?
Well because of Chris's incompetence,and his elusion that his !failed! bucking coil bullshit was part of my machine. Now let's look at his video below,where you can see his failed attempt at replicating my RT. You will also note the size of the motor he is using,which was the large universal motor as was my V1 of the RT. This was the motor being used when i gave those dimensions in the schematic you provided,and yet you posted the V3 engine along side those dimensions instead of the larger V1 motor-->odd how you would do that NoGo lol  ::) Odd how Chris used the larger V1 motor in his video  ::). You will also note Chris has a coil wrapped around the stator,which none of my RTs have==this is how he use to totally botch things up continually.
https://www.youtube.com/watch?v=dLn5k31fL7s
You will also note that Chris loves saying my name,so one has to wonder as to who is fascinated by who  ::)
So the truth is,i removed the RT due to Chris's incompetence,and the damage he was doing through his own low grade skill's,and inability to carry out an accurate replication.
He claimed that you could not drill a 19mm hole through a laminated core as i did.
He even said he took it to two engineering shop's,and they couldn't do it either--i still have the emails right here to prove this. I then had to make a video to show Chris how it was done.
So this go's to show just how low his skill grade was. He also said you cant get the stator out of the steel housing of the smaller universal motors without damaging the steel housing. I also had to show him how to do that--in the same video.
https://www.youtube.com/watch?v=u3nWWtmPq6I
So the RT was never removed,just taken away from that idiot Chris's view,as none of us need him botching up anything else. He claimed his bucking coil garbage was OU,but then we found out he used AC coupling on his scope to make power measurements--yes,that's how stupid he was.
In fact NoGo,he botched things up just as much as you have--odd that  ::)
Brad
