Flywheel Generator Project
Started by SkyWatcher123, August 07, 2019, 11:42:48 AM
SkyWatcher123
Hi all, decided to follow through with the project that was not finished in the past, was posting to the 'GEM' thread previously, where user that_prophet was sharing similar ideas.Though his version did not seem to emphasize the use of heavy flywheel, think it is needed though.Started working on building the setup a few days ago.
It was going to be like the Wilson wheel generator, though decided to use a separate pulley for the motor and a belt around the heavy mdf flywheel itself, which will be three 1/2" thick, mdf discs secured together for now.
Here is the cad drawing of the project.peace love light  :)
(https://i.postimg.cc/VrjThs6N/Flywheel-Generator.png)
seychelles
SKY THOSE HOT GIRLS WILL GIVE ME FREE ABUNDANT ENERGY
FOR THE REST OF MY EARTHLY LIFE..
SkyWatcher123
Hi seychelles, not sure what you are speaking about.
So the project is coming along, built a homemade router circle guide out of 1/4" thick mdf, with a 5/8" diameter pivot channel, so the circle diameter is adjustable.The good thing about this is, it will have the intended shaft hole size right from the start and the discs will be more true and accurate, without having to do any extra steps.It looks like each 2 foot diameter, 1/2" mdf disc will weigh around 5.7lbs., so about 17 pound flywheel to begin this project, can add more discs if needed.peace love light  :)
seychelles
my suggestion is to power the flywheel from it,s rim so to
get the advantage of leverage, 2 a pma should be connected directly
to the main shaft. 3 the acceleration of the flywheel should be grater that of
gravitational acceleration is approximately 9.8 m/s2, THEN YOU ARE
GARUNTIED TO GET FREE ENERGY..
seychelles
