Up to 99% less mass and energy consume by aequivalent comfort
Started by lancaIV, August 29, 2019, 07:14:39 AM
Quote from: lancaIV on May 16, 2020, 09:17:13 AM
::)  http://www.rexresearch.com/hooper/3610971.htm
Figure 6 :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20101004&CC=PT&NR=104492A&KC=A
Figure 8 :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=kompanek&IN=&CPC=&IC=&Submit=Search
fuel combustion enhancerhttps://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=3&ND=3&adjacent=true&locale=en_EP&FT=D&date=19770726&CC=US&NR=4038348A&KC=A
https://www.google.com/search?q=rexresearch+bxv&rlz=1C1AVFC_enPT797PT797&oq=rexresearch+bxv&aqs=chrome.0.69i59.8963j0j7&sourceid=chrome&ie=UTF-8
http://www.rexresearch.com/ide/ide.htm
https://www.google.com/search?rlz=1C1AVFC_enPT797PT797&source=univ&tbm=isch&q=rexresearch+bxv&sa=X&ved=2ahUKEwjIpdmwu7jpAhVt7OAKHVLPAx4QsAR6BAgIEAE&cshid=1589634933024188&biw=1366&bih=636
Bon/Bom/Bonne Appetit !
OCWL
p.s.: probably usefull : https://www.google.com/search?q=patentauction.com+superconductor&rlz=1C1AVFC_enPT797PT797&oq=patentauction.com+superconductor&aqs=chrome..69i57.15819j0j7&sourceid=chrome&ie=UTF-8
https://www.patentauction.com/patent.php?nb=13984
https://www.google.com/search?q=superconductive+ink&rlz=1C1AVFC_enPT797PT797&oq=superconductive+ink&aqs=chrome..69i57.8226j0j7&sourceid=chrome&ie=UTF-8
wireless transmission : efficiency ?                  http://tube.uz/video/118103/how-to-make-100-free-energy-generator-magnet-using-light-bulb-exhibition-project-2018/
Here in the forum from member Franco Malgerini
http://www.serenitystreetnews.com/HERSTORY%20CRAMNOTES/5dterra%20NOTES%20AUDIO%20VIDEO/ebooks/ebooks/Rivista%20free%20energy%20e%20scienza%20alternativa%20-%20Altra%20Scienza%20n.16.pdf
7. Floyd A. Sweet NOTHING IS SOMETHING
The Fallacy of Displacement Current ~ Conventional electromagnetic theory proposes that when an electric current flows down a wire into a capacitor it spreads out across the plate, producing an electric charge on the plate which in turn leads to an electric field between the capacitor plates. The valuable concept of continuity is then retained by postulating "after Maxwell" a displacement current. This current is a manipulation of the electric field (E) between the capacitor plates which has the dimensions of electric current and completes the flow of electricity in the circuit. This approach permits us to retain Kirchoff' slaws and other valuable concepts even though superficially it appears that at the capacitor there is a break in the continuous flow of electric current. The flaw in this model appears when we notice that the current entered the capacitor at only one point on the capacitor plate. We then are left with the major difficulty of explaining how the electric charge flowing down the wire suddenly distributes itself uniformly across the entire capacitor plate, at a velocity in excess of the speed of light. This paradoxical situation is created by a flaw in the basic model. Work in high speed logic conducted by Ivor Catt has shown that the model of lumped capacitance is faulty and displacement current is an artifact of the faulty model. Since any capacitor behaves similarly to a transmission line it is no more necessary to postulate a displacement current for the capacitor than it is necessary to do so for a transmission line. The excision of "displacement current" from electromagnetic theory has been based on arguments which are independent of the classic dispute 12 over whether the electric current causes the electromagnetic field, or vice versa.
Ivor Catt
https://www.google.com/search?q=ivor+catt&rlz=1C1AVFC_enPT797PT797&oq=ivor+catt&aqs=chrome..69i57.4255j0j7&sourceid=chrome&ie=UTF-8
Induced Motional Field: Negative Energy ~ Conventional theory says that electric fields and magnetic fields are different things. Consider for a moment a charge with an electric field around it. If the charge is moved a magnetic field develops and the moving charge constitutes a current. If an observer were to move along with the charge, he would see no relative motion, no current, and no magnetic field. A stationary observer would see motion, current and a magnetic field. It would appear that a magnetic field is an electric field observed from a motional reference frame. Similarly, if we take a mass with a gravity field around it and we move the mass and create a mass current, a new field is also created. It is a different kind of gravity field with no source and no sink. It is called the Protational field also known as the "Lense-Thirring Effect". This field an its governing principles will form the basis for future antigravity devices.
Within the confined area of the Vacuum Triode box, the spacetime continuum is reversed by the fields that are produced in the presence of excited coherent space flux quanta.
These quanta have been attracted from and ultimately extracted from the virtual vacuum, the infinitely non-exhaustible Dirac Sea.
For a more detailed mathematical format see Appendix A, a paper on "The Phase Conjugate Vacuum Triode" by T.E. Bearden, April 23, 1987. Much of the theory which likely applies to the vacuum triode has been developed in the field of phase conjugate optics. With regards to over-unity phenomena it is important to note that so long as positive energy is present in a positive/flowing time regime unity and over-unity power gains are not possible. The summation of the losses due to resistance, impedance, friction, magnetic hysteresis and eddy currents and windage losses of rotating machinery will always reduce overall efficiency below unity for a closed system. The laws of conservation of energy always apply to all systems. However, the induced motional E-field changes the system upon which those laws need be applied. Since the vacuum triode operates in dimensions more than four and provides a line between the multi-dimensional reality of the quantum state and a link between Dirac Sea we are now dealing with an open-ended system, not the closed system within which all conservation and thermodynamic laws were developed. To achieve unity, the summation of all magnetic and ohmic losses must equal zero. To achieve this state negative energy and resistance moves to zero and all energy flows along the outside of conductors in the form of a special space field. Negative energy is fully capable of lighting incandescent lights, running motors, and performing all of the functions of positive energy tested to date. When run in parallel with positive energy however, cancellation (annihilation) of opposing power types occurs. This has been fully tested in the laboratory. Once unity has been achieved and the gate to the Dirac Sea opened, over-unity is affected by loading the open gate more and more which opens it further to the point where direct communication/interaction with the nucleus of the atom itself is achieved. Output of the vacuum triode is not proportional to the excitation input as the output produced by the device is directly proportional to the load which is placed upon it. That load is the only dependent variable for device output. The triode' soutput voltage and frequency always remains constant due to the conditioning of the motional E-field in the permanent magnets and the small regulated excitation signal which is provided through a small oscillator. Regulation remains constant, output locks into an in-phase condition (cos = 1 Kvar = 1) under all load characteristics. The vacuum triode is a solid state device consisting of conditioned permanent magnets capable of producing a motional field. This field opens the gate to the Dirac Sea where negative energy is able to flow from an into the triode' sreceiving coils. The coils are very small diameter copper wire but are capable of producing in excess of 5 kilowatts of useful power; this in itself is a clear indicator that the type of electrical energy provided by the device is not conventional. The wire sizes employed by the device would not be capable of carrying such large currents without excessive heat gain, however, the triode' s coils actually run cooler when loaded at 5 kW. The fundamental magnets have been broken free of their binding forces which constrained them to be steadystate single pole uniform magnetic flux devices. They are now able to simply support mass, as demonstrated with the transformer steel illustration. They can now easily be made to adopt a dynamic motional field by applying a tiny amount of excitation. Specifically, 10V @ 1 mA (10 mW) of excitation at 60 Hz. will enable the coils of the triode to receive from the Dirac Sea in excess of 5000 watts of usable negative energy; how much more can safely be removed has not yet been determined.
Proc. 26th Intersociety Energy Conversion Engineering Conference (August 4-9, 1991, Boston, MA):
https://de.wikipedia.org/wiki/Lense-Thirring-Effekt
Dirac sea  8)  by Dirac surge
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=3&ND=4&adjacent=true&locale=en_EP&FT=D&date=19990824&CC=US&NR=5942858A&KC=A
Harry Kompanek,US2002108749
[ 0035] [0036 ] and [0042]
A good night ,
sincerely
OCWL
p.s.: the above applied in US4524746,inventor Earl S. Hansen
       Probably some remembers : Rudolf Gunnerman(n) and his alternative fuel
       and "Papenburger Treibstoff" www.egm-international.com and "Wrbelwandler"-Technology
      Frank Polifka "Tornado in a can", Windhexe
The V-Tech Reinhard Turbine €/KW
WO20046067946,Stepahn Adre Ruolph and Peter Reter Rudolph
Alimentation : up to 90% less land and water use and less cows
Instead "cow"-milk "other natural extract"-milk
https://kirschnerskorner.com/2020/02/20/environmentally-sustainable-plant-based-milk/
https://www.quora.com/What-is-vertical-farming-Why-is-it-better-than-horizontal-farming-Which-one-yields-more
http://www.verticalfarminstitute.org/vertical-farming/
https://i1.wp.com/www.verticalfarminstitute.org/wp-content/uploads/2017/09/vfi-Info_Flaechenverbrauch-Ernaehrung-1.jpg
https://i1.wp.com/www.verticalfarminstitute.org/wp-content/uploads/2017/09/vfi-Info_Vertical-Farm_Funktionen-1.jpg
https://www.eitfood.eu/blog/post/is-vertical-farming-really-sustainable Open field/green house yield
From conventional  horizontal agriculture,except " hanging gardens in Babylonia" and "floating islands",to platform and vertical (city-/urban-) farming,including aqua-/hydro-ponds,from 128 sqm "horizontal farming" aerea to less than 1 sqm "vertical farming" = 99% less area for te same alimentation in Kg gain
https://www.google.com/search?q=urban+farming+100+sqft+plot&rlz=1C1AVFC_enPT797PT797&oq=urban+farming+100+sqft+plot&aqs=chrome..69i57.13485j0j7&sourceid=chrome&ie=UTF-8
100 sqft~ 10 sqm plot horizontal vegetables growth,organic gardening,with 500 US$ grocery value :
https://www.researchgate.net/figure/Estimated-yield-of-a-Vertical-Farm-compared-to-traditional-agriculture_tbl1_259702659
https://www.researchgate.net/publication/259702659_Up_Up_and_Away_The_Economics_of_Vertical_Farming#pf5
With construction prices by 3d-printer about 375 Euros (all inclusive) and 0,01 Eurocent/KWh electricity costs ?
Whats about sub-telluric/terrestric caverns/tunnel farming, ~ indoor farming,and on  surface classical farming !?
Less costly and the excavated minerals for exploration !
Mountains to "farming domes" !
vertical farming  then horizontal area need 1 qm/0,1 sqmt,high dependent
Trans-/portable farm : inflatable shelter, box,container,greenouse platform (N55.dk  http://n55.dk/MANUALS/SPACEPLATESG/spaceplatesg.html         )
Princeton Uni experimentation : vertical wheat growth https://www.princeton.edu/news/2017/11/02/room-growth-princetons-vertical-farming-project-harvests-knowledge-budding-industry
www.canlaser.com/en/Deserts.html  for diametrical terraces  ::) farming
~ Le Corbusier Skelett-platform"Dom-ino" as "urban-/city- farming" agriculture land winning vision https://en.wikipedia.org/wiki/Dom-Ino_House
U.N. " nutritition pyramid", let us hope not in Fortune500 possession  :P 8) ;)  https://en.wikipedia.org/wiki/Food_pyramid_(nutrition)
"Dr.med. Schreber small gardening" https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.wikipedia.org%2Fwiki%2FMoritz_Schreber  and "colonies" https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.wikipedia.org%2Fwiki%2FKleingarten ,in Germany a conventional solution like in Russia the "Datscha"-colonies
When each one stores the vegetable and fruits kernel fom daily alimentaton and use as seet and let it  grow this plants probably gives a fruitfull wintergarden.
https://www.sueddeutsche.de/muenchen/fuerstenfeldbruck/erfindergeist-der-patente-mann-1.4192007
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.sueddeutsche.de%2Fmuenchen%2Ffuerstenfeldbruck%2Ferfindergeist-der-patente-mann-1.4192007
One of his projects "went through the world press 40 years ago" and even put it in the Guinness Book of Records for a few years, recalls Gruber. He managed to grow every imaginable plant in miniature format - a sunflower was eight centimeters tall. The former Yps youth magazine had its wonderful mini-seeds enclosed in small bags in a print run of 400,000 copies. Gruber believes that this development would make colonizing Mars easier, for example, because you would not have to overload the spaceships: seeds and root balls that have shrunk to one hundredth of normal size. The only problem:Gruber was awarded the highest German award for his miniature plants in 1988 with the Diesel Medal from the Institute of Invention, and the International Federation of Inventors (IFIA) knighted him - but the matter of settling on Mars has not made much progress to date. No other interested parties have reported. That is why the small pots with preserved shrinking plants such as stinging nettle, pegonia or philodendrons
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=96&ND=3&adjacent=true&locale=en_EP&FT=D&date=19780704&CC=US&NR=4098021A&KC=A
(rain-) worm compost  https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Flombritonus.ch%2Fwurmkompost%2F
superthrive plants nutrition or similar
https://www.google.com/search?q=superthrive&rlz=1C1AVFC_enPT797PT797&oq=superthrive&aqs=chrome..69i57.5260j0j7&sourceid=chrome&ie=UTF-8
www.magnetizer.com as water softener /polarizer/ionizer (exGDR estatal institutions experiments,also Israel Negev : 20%more gain)
Planting with magnetical NS orientation ?
https://www.google.com/search?q=rexresearch+electroculture&rlz=1C1AVFC_enPT797PT797&oq=rexresearch+electroculture&aqs=chrome..69i57.10589j0j7&sourceid=chrome&ie=UTF-8
http://www.rexresearch.com/elculture/elculture.htm
diversification : https://www.thebetterindia.com/169520/chennai-hydroponics-grow-plants-at-home-india/
https://www.youtube.com/watch?v=5kO6-PpgZ1M
