Up to 99% less mass and energy consume by aequivalent comfort
Started by lancaIV, August 29, 2019, 07:14:39 AM
For a little more price market autonomy and an hobby with gain,social and economical and as sustainable development with heritage value :
www.smallfootprintfamily.com
1000 square-foots ~ 100 sqm plot area
" measuring right" ,by which assumption and given physics formula equitation conditioning !?
"light devices" as indicator :
are light devices simple transformer,from electric energy in Watt,VA or photonic/phononic converter with amplyfing factor if not measured by fixed 1 meter distance ?
1 Watt electric bulb heater input and up to 4 thermic Watt output
Is this not a FE-device efficiency measurement risc if totally the C.O.P. ≥ 1 ,let us fix with C.O.P. average 2,0,
but ≥ 2/bulb C.O.P. ≤4 =
FE-device without bulb C.O.P. = FE-device efficieny 0,5 or 50% !?
Marzahn photonic light chamber 650 Watt DC solar output by 12 x 13 Watt electric bulb input
650 /156 = +- 4,2
Baquero Menendez light chamber : 8x 240 Watt solarcells = 1920 Watt total output and 500 Watt e-bulb as photonic source
Lasersaber,Gerard Morin,JL Naudin experiments( GenX) et cetera :
How often calculations are irrative because there is the conventional and wrong ( learned ?)assumption that 1 Watt electric input into electric to light or heat conversion is effective ≤ 100% or C.O.P. ≤ 1 ?!
Only 1 fact : the improvements in lumen/Watt output from photonic devices  !
                      less phononic= wave = magnetic proportion
For heat : heat elements with electric consumption savings up to 50 % based by silicon-carbide or graphit or material mix ike HTM wwwcanlasercom
Wave : speed velocity ?     Decrease from source distance in vacuum or dry/humid  air ?Particle : speed velocity ? Decrease from source distance in vacuum or dry/humid air ?
Non magnetic to magnetizable material = graphene,
non ferrit magnetic material = repulsion/bonding forces
Bulk material specification to the same nanograin material specification with now higher particle orbitally  freedom degrees,more effective surface area per cubic or gram !
Michael-Morley experiment : no win ,but also no loose ? With hyerspace beam option ?
Being ever ready for changes ! 8) :)
Is the air/air and air/water thermal change heat pump process with average and conventional C.O.P. 3 wrongunderstand,as heating /cooling process and effective C.O.P. alternatives like Gerhard Beiers Resonator,Joseph Yater thermionic cell panel ,Dr.phy. Helmut Reichelt et al. Graphit thermionic paper cell and only heating Jianqui Zhang his bulb radiation heat pump !?
The OSMA TECH paint ( Adnan Erkol) ,for heating/cooling : which material/mineral based for this given several  example effects?Cristalin ? Cone ?
Gudn Morjn,we can see what by professional and winning motivated sin is possible :
Formula 1 wheels changes in less than 15 seconds and related this the com(m)ercia wheels change in cars garages like "Pit stop" and the process price :" for 15 seconds net work"- value !
This example for electric devices engineering,modular and easy and fast  parts changing concept,
as current example e-cigarrets with exchangeable coils,atomizer,battery-pack and "liquid" !
Motors,generators and transformers : stackable,capacity/potential/power output step up and/or step down !
How much time to change primary/secondary/rotor/stator coils or permanent magnets !?
How much time for change of friction parts( bearing) !?
How much time for friction zones anti-wear coating ( Motor-Kote,molybdaen et cetera )
EDM : electro discharge milling as taking and giving (re-layer coating) process : used parts refurbishing !
From "drop away society" to "reuse society",the US Pioneer Corps study result in the 90':up to 50% less material consume and expenses !
Totally a cost and environmental concerned citizen can save in costs :
    our world-wide WTO/WIPO market and the trade rules conditioning
100 price units "com(m)ercial propaganda TM ware f.e. meaning "utility model(l)/technical patent saved " as reproduction barrier in mind ,individual buy,ready to use
30 units the same as " no propagated TM  name"- product,individual buy,ready to use
15 units the same product,fob factory and group buy,ready to use      ---------------------------------------------------------------------------------
100/15 is the average ratio from " new " [com(m)ercial monopole  rights claimed] products"
7,5-10 units the same product as kit ( DIY-monting) ,fob factory and group buy
So we can calculate and measure by ware mass/price  that 90% of the price is not the ware related : but over-head costs !
Seconds that our behaviour and "ware"-treat defines the efficiency and long-life of this product,instesd one-two years warranty-lifetime up to five or ten years use !
By friction-parts change and no-rust materials 20-.... years !
Alimentation : foreign service price to "own urban gardening/farming": 80% less expenses !
Medical service: from "placebo industry" and "placebo physiants" to self-healing processes : 90% less expenses !
Ground policy : for food/ for alternative energy production / for production in geral
up to 90% less continental ground need ! Instead on ground in air or on water !?
Portugal,E.U.-member,social standart ,minimum wage ( Profession ? Age ?:Political orientation ? Nationality ? .... )
PORDATA,www.pordata.pt
2020 : 635 Euros p.m                   1974 16,5 Euros p.m.
635 Euros per month x 14 times(12 monts year and 11 months work/1 month holiday  )Wages-taker real productivity and efficience ?
Minimum wages,brut(work-station/place total costs)  / 0,32( enterprise/company factor) =
(635 x14 x1,2 )/0,32 ~ 10668 /0,32 ~ 33337,5  Euros productivity value minimum
( house maid versus house keeper,industrial worker versus service worker 4.class versus academician )
Minimum wages from fixed contract to per hour contract freedom(e) ,by both sides interests !?
All in the " independent worker/Selbstand"- stadium ! "Kommerzielle Volljaehrigkeit/-Haftung!"
As industrial worker,for " monopol rights"- holder delivery : 33337,5 Euros x 6 =
     200025 Euros net trade market price productivity per yearly minimum wage
All estates with " minimum wages per month/week/hour" have to define " by minimum productivity" ,        for the work-place,for the legal trade market value !
         President-office search function ! If not,useless functionary(m/f/d),away with it,new election !
The internet makes City-buying malls obsolet,the seasonal sales drops up to -90% are common factory outlet prices,24/365 sitation !
Cities as " trade behavour museum" is a little over-sophisticated ! Buildings demolition !
We will see world-wide " monopol rights companies" "un-" friendly spin offs,cause there are not anymore real " monople rights" in legal validation, "TM-labels someone can take away from old ware and resign ex-" no name":
that is today the conventional "Mode"-companies treat : "label"- value trading !1 Euro T-shirt + "TM"= up to 25 Euros price-offer
- 90% sales/liquidation offer are only by "low calculated sell margin" a buyer win !
all actual com(mecial propagated products have "open source" digitzeable and mass-produce-able pendants !Mini-home fabrics/fabrication and Mini-home-offices !
In the house where I am living was before a " small textile confection",delivering f.e. ZARA/Indutex !
Garment delivery and ready to use " textile": less than 1 Euro per shirt com-participation ,time invest per part ?
And how confident the payment by  the "client",independent how great ( their mouth,their economical reality !?)
Even "States" as com(m)ercial trade partners are bad payer !
About "(il-/legal)margin"  knowledge as economical and economics life-partcipant ,sector pharmaceutics/petrol/cosmetics/textile(wear/cars : COINDU)
700 x 14 x1,2 ~ real and classical and legal constitution-conform social -accumulated credit-inflation released-  70 x 14 x1,2     ergo  "DIY villages"- development and estates,industry,trade companies,market  illegality destroy !
                            Destroying legal,with legal tools and 100% transparency and calling open their names !
                           4.technical Evolution,TIER 4.0 :
                           50% less employment = 50% time-share or up to average 50% disemployment ( seasonal 75/25)
50% less industrial factories,apartments(ex-bureau/fillial) gives local more than 90% price decrease !
When the Rating-Agencies Moody's/Standart&Poor's/Fitch will have to rate the US-Estate treasury solidity and solvity then they will probably have to remark : anymore " investment grade"
Great-Britain after the Brexit as "low tax"-country : 15% real total  tax ( all included) similar the work-platform Singapore will bring an european tax-down melting ! 10% for the real poor and up to 5% for the public  administration !
The unconstitutional World Vision
ramset
Thanks Grandma
1000 calories ? I mean 1000 KILO-calories per day !
I know about the british post-WW2 zone  nutrition ration about 800 KILO-calories per day ! So,under given condition,not far away from healthy living ! ::) ;)
Less calories = less body work/in cell incineration ,okay : body work (Wpeak and Whour) and outside body climate dependent ! Water : energy content per litre ?
What means 1 kcal or 1000 kcal in Watt and/or Watth : https://www.hug-technik.com/inhalt/ta/leistung.htm
So kcal/h = (kcal divided 24)/day
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.diabetes-news.de%2Fernaehrung%2Fkalorien-broteinheiten
https://www.tk.de/techniker/magazin/ernaehrung/uebergewicht-und-diaet/wie-viele-kalorien-pro-tag-2006758
Age-related calorie needs
Age
Men                                                     Women
15 to under 19 years
10,460 kJ / 2,500 kcal                         8,370 kJ / 2,000 kcal
19 to under 25 years
10,460 kJ / 2,500 kcal                         7,950 kJ / 1,900 kcal
25 to under 51 years
10,040 kJ / 2,400 kcal                         7,950 kJ / 1,900 kcal
51 to under 65 years
9,200 kJ / 2,200 kcal                           7,530 kJ / 1,800 kcal
65 years and older
8,370 kJ / 2,000 kcal                           6,700 kJ / 1,600 kcal
