Up to 99% less mass and energy consume by aequivalent comfort
Started by lancaIV, August 29, 2019, 07:14:39 AM
https://translate.google.com/translate?sl=auto&tl=en&u=https://www.trendsderzukunft.de/
https://hnuq3o364xcy6pxv773wp2w7sm--www-tagesschau-de.translate.goog/wirtschaft/weltwirtschaft/afrikanische-freihandelszone-101.html
1 billion houses to build ?
https://72fs4jx7slokr27jkrzcsh5tm4--reset-org.translate.goog/blog/othalo-will-gleichzeitig-wohnungsnot-und-plastikverschmutzung-afrikanischen-laendern-angehen-12
Sand bag houses ! Instead or alternatively https://polycare.de/  or https://en.wikipedia.org/wiki/Moladi
Southafrican Cape Town Prof. Abbott his cooperation : Ecobeam
https://www.google.com/search?client=firefox-b-d&q=ecobeam+technologies
The Ecobeam building technology is a versatile and eco-friendly timber frame building system that involves the construction of structures using Ecobeams as well as Ecobags (sandbags). The Ecobeam system offers benefits when compared to conventional building including up to 40% cost savings, bullet proof and earthquake resistant walls which offer thermal and acoustic properties.
http://www.earthbagbuilding.com/articles/eco-beam.htm
http://www.earthbagbuilding.com/projects/projects.htm
plastics bags from waste oceanic plastics continents recycling ! Or plenty bottles on ancient natural virgin beaches !
https://www.google.com/search?client=firefox-b-d&q=plastics+to+living+islands
to
https://www.google.com/search?client=firefox-b-d&ei=HD35X8qMEqzBlwSOnqyIDQ&q=plastics+to+artificial+living+islands&oq=plastics+to+artificial+living+islands&gs_lcp=CgZwc3ktYWIQDDoECCEQClDkwgFY7-oBYIj-AWgAcAB4AIABW4gB0QeSAQIxMpgBAKABAaoBB2d3cy13aXrAAQE&sclient=psy-ab&ved=0ahUKEwjKiuSljY7uAhWs4IUKHQ4PC9EQ4dUDCAw
Look also jovoto : https://www.google.com/search?client=firefox-b-d&q=jovoto+house+sand
as example https://www.jovoto.com/projects/300house/ideas/12498
https://planetaryrenewal.org/
Cooling and heating with "Zero-Grid-Energy-Drive" easy handling !
and
https://www.jovoto.com/projects/300house/ideas/12769
https://www.jovoto.com/projects/cumulus-green-2020/ideas/75876
dry zone :
https://www.jovoto.com/projects/h2overhaul/ideas/18590
and
http://mtbest.net/  http://mtbest.net/energy_efficiency.html  0,8 KWh to optimized 0,25 KWh electric consume per day
Sincere
OCWL
from mtbest 0,8 KWh to 250 Wh at first,then 125 Wh
by heatelement,resistor connection,heat reflective coating, controler
and motor and/or motor-generator
power storage :
https://overunity.com/18316/up-to-5-faradcube-cm-actually-1-kwh40-grams/msg538538/#msg538538
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.carmart.ch%2Fumwelt%2Fpreise-fuer-batterien-von-elektroautos-fallen-massiv-in-10-jahren-90%2F
battery charge technology like :
http://www.bticcs.com/     5000 charge cycles by 1KWh storage and 250 Wh daily consume = over 50 years battery duration
inverter like :
https://web.archive.org/web/20130901130624/https://www.powerguru.org/planar-transformers-are-essential-for-truly-efficient-electrichybrid-vehicles/
1.
https://overunity.com/8067/no-electric-cars-for-a-long-time-to-come/msg549256/#msg549256
                                                  and
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=WO&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=9628882&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
This means that an electric motor with a nominal output of 1000 watts, if it were operated with the free electrical direct current from the downstream coils of part C, can produce an output of 25,000 watts (25: 1). The same applies to the three other power sources of the upstream coils of part C 1,2 + 3.
2.
only to electric motor drive gasoline car conversion :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20001207&CC=DE&NR=10011074A1&KC=A1#
                                         and Uwe Jarck technique applied : consume per hour/ per 100 Km ?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=de_EP&FT=D&date=20001020&CC=FR&NR=2792258A1&KC=A1#
                                         and Uwe Jarck technique applied : consume per hour / per 100 Km ?
heat pumps/chillers with Jarck technique : C.O.P.  100
home refrigerators
friction heater
mtbest energy efficiency and 125 Wh per day easy reachable each 100 years battery recycling  ;)
Water from air generator working as same as dehumidifier :
https://www.youtube.com/channel/UCYdxSlaQpxVmTSG5gcTUl8w
Sullivan Shaun 600 Watt per hour 1/25 would not be bad ,is it not ?
Small Low Cost 6000 Btu Machine that can Harvest up to 40 US gallons of clean drinking water per day. There is no other technology in the world that can harvest large amounts of clean drinking water from such a small machine (low Btu's) at a low cost per gallon / liter.
40 gallons x 3,785 liter/gal = circa 150 liter water per day / 5 liter per capita = 30 capita per generator
+Osma tech coating  + Melvin Prueitt compressor (M.E.C.H.):10 Watt electric per hour
https://web.archive.org/web/20110208022524/http://www.solterrah.com/
beside:
https://www.irishtimes.com/news/science/limerick-researchers-develop-material-that-produces-water-from-air-1.4065959
international minimal house challenges and solution examples :https://web.archive.org/web/20081225185633/https://www.edilportale.com/livingbox/
https://web.archive.org/web/20190719051554/http://fabprefab.blogspot.com/
living homes with later drone e-drive
http://prefabcosm.com/blog/2008/01/22/historic-prefab-venturo-and-futuro-house/
the international Elemental challenge and more than 100 competitors-plans
https://web.archive.org/web/20130220115643/http://www.elementalchile.cl/libro
http://n55.dk/  combined with    http://schemata.jp/paco/
here https://www.detail.de/ getting plans for
https://www.sturm-wartzeck.de/projekt/kubus-energieautaker-experimentalbau/
and
https://cado-eva.tumblr.com/post/586617379/transportable-housing-container-finland-by/amp  or "Kesae-Konti"
https://translate.google.com/translate?sl=auto&tl=en&u=https://72fs4jx7slokr27jkrzcsh5tm4--reset-org.translate.goog/blog/othalo-will-gleichzeitig-wohnungsnot-und-plastikverschmutzung-afrikanischen-laendern-angehen-12
Plastic panels instead wood ? https://cdn.stylepark.com/articles/2012/build-it-in-the-morning-move-in-in-the-evening/l2_v333727_958_480_357-4.jpg?mtime=20160927105507&focal=none
Idea : ,,Packaged House System" von Walter Gropius und Konrad Wachsmann
Going some decades,fifthy years, temporary back : 1971
Die architekturgeschichtlich bedeutendste Ausstellung gebauter Häuser des zwanzigsten Jahrhunderts war [/font]die Weißenhofsieldung von 1927. Für die Pionierzeit des Bauens mit GFK war die wichtigste Ausstellung  die Internationale Kunststoff-Haus-Ausstellung  ́71 (IKA ́71) in Lüdenscheid, BRD mit 15 Exponaten, welche sich als IKA ́72 auf insgesamt 30 Exponate erweiterte [Doernach, 1972].
The most important exhibition of built houses of the twentieth century in terms of architectural history was the Weißenhofsieldung from 1927. For the pioneering days of building with GRP, the most important exhibition was the International Plastic House Exhibition '71 (IKA'71) in Lüdenscheid, FRG with 15 exhibits, which are known as IKA '72 expanded to a total of 30 exhibits [Doernach, 1972].
file:///C:/Users/beatr/AppData/Local/Temp/Reidemeister%20195.pdf
https://www.google.com/search?source=univ&tbm=isch&q=ika+71+luedenscheid&client=firefox-b-d&sa=X&ved=2ahUKEwikkdf6q5vuAhUDu3EKHahZDZgQ7Al6BAgLEAo&biw=1366&bih=633
https://e-pub.uni-weimar.de/opus4/frontdoor/deliver/index/docId/821/file/Voigt_pdfa.pdf
page 48 : DO ,fg2000 by Wolfgang Feierbach
page 49 : Minimalhaus Peter Huebner,Neckartenzlingen   ( also Casanova-Raumeinheiten,1972 Olympiade Muenchen)               https://thefuturohouse.com/images/collection/x_magazin_pages_44_45.jpg  also Huebner the yellow Delta-Ferienhaus
Die Möglichkeit der Überwachsung von Gebäuden durch Kletterpflanzen nutzte Peter Hübner für seine als Wohn- und Büroräume genutzten Raumzellen des Systems Casanova (Weiterentwicklung 1972: [1971/07]).
https://i2.wp.com/www.plus-bauplanung.de/wp-content/uploads/2020/04/00_Haus-H%C3%BCbner_Janzer_010.jpg?w=255&h=272&ssl=1
many prototypes/models for replication ! Free plans ! basic material recycleable !
                                                 Technik = Kunst = Arts
Instead aluminium "Kunststoff/synthetic or technical material " for the Buckminster Fuller dymaxion bathroom using :
https://www.google.com/search?source=univ&tbm=isch&q=buckminster+fuller+dymaxion+bathroom&client=firefox-b-d&sa=X&ved=2ahUKEwjBw8-0rpvuAhU0rHEKHYppB34QjJkEegQIARAB&biw=1366&bih=633
Die Raumzelle als kleinster nutzbarer Raum wurde in den 1950er Jahren als eigenständige Architekturform gegründet. Seitdem beflügelt sie die Phantasie der Architekten und Designer. Die Sonderausstellung  ́Box für das Existenzminimum` im Juni 2000 in Dresden hat Prof. Dr. Günther Feuerstein, BTU-Cottbus zu zahlreichen Assoziationen, philosophischer, künstlerischer und architektonischer Natur inspiriert. Er sieht die Zelle als minimalsten Raum, als Zufluchtsort, die privateste Zone des Alleinseins, ein Individualraum. Das Leben beginnt in einem Ei, der natürlichsten aller Kapseln und endet im Sarg, der menschengemachten Zelle.
The room cell as the smallest usable room was founded in the 1950s as an independent form of architecture. Since then, it has inspired the imagination of architects and designers. The special exhibition 'Box for the subsistence level' in June 2000 in Dresden was presented to Prof. Dr. Günther Feuerstein, BTU Cottbus inspired numerous associations, philosophical, artistic and architectural. He sees the cell as the most minimal space, as a place of refuge, the most private zone of being alone, an individual space. Life begins in an egg, the most natural of all capsules, and ends in the coffin, the man-made cell.
        " Futuro " applied
                                               https://thefuturohouse.com/Futuro-House-Exhibitions.html
                                                             https://youtu.be/Ox9siX01oiA
https://ms-my.facebook.com/labullesixcoques/videos/petite-animation-de-la-bulle-six-coques-de-mon-papa-jean-maneval/460333551470577/
        n55.dk
                                                             http://n55.dk/MANUALS/MICRO_DWELLINGS/micro_dwellings.html
                                                             http://n55.dk/MANUALS/URBANFREEHABITAT/urbanfreehabitat.html
                                                              http://n55.dk/MANUALS/WALKINGHOUSE/walkinghouse.html
                                                             http://n55.dk/MANUALS/HYGIENE_SYSTEM/hygiene.html  ::)
                                                             kitchen/bathroom units
                                                             https://www.jovoto.com/projects/300house/ideas/12735
                                                             https://web.archive.org/web/20090309095727/http://www.idee.ch/hausequipment.html#times
                                                             https://web.archive.org/web/20111101154842/http://www.geolitesystems.com/hm.html
                                                             toilet/bath units
                                                             https://karmod.eu/products/mobile-toilet-shower
                                                            https://architekturvideo.de/je-kleiner-desto-besser-chu-200-das-vier-quadratmeter-haus/
Sincere
OCWL
Let us do an E.U. european low-e/energetic private household economy outlook :
1975 :
http://www.habiter-autrement.org/12.energies/16_ener.htm
Autonomous House                                 UK average
floor area 176 m2                                              82 m2
space heating 1,400 kWh                             12,900 kWh
water heating  1,900 kWh                              5,700 kWh(3)
lights, appliances and cooking 1,200 kWh     3,000 kWh(4)
total consumption 4,500 kWh                       21,600 kWh
renewable energy:
wood                   1,400 kWh
solar electricity    1,600 kWh
total non-renewable energy 1,500 kWh        21,600 kWh
water in litres per head per day 34 160 (5)
2021 :space heating  p.a.  82/176 x 1400 KWh = 660 KWh for average UK construction standard ,
by example E.U.-member Ireland : 15 KWh PE/sqm construction standart ( Nearly Zero or Solar Passive House called )
                                                    15 KWh electric / 1,8 energy mix PE factor = 8,33 KWh/sqm x 82 sqm = 683 KWh (near 660 KWh !)
since CIAM conferencece 1929 the fixed social housing standarts : 30,5 sqm + 9 sqm per capita : by ideal family : 4  capita = 66,5 sqm living/floor area
Federation of American Scientists social housing numbers : 32-38 sqm starter family      72-78 sqm expanded family
starter/ideal family (man/wife/m./f. childs)  level by IKEA :
https://www.google.com/search?q=ikea+35+sqm+prototype+house&rlz=1C1AVFC_enPT930PT930&ei=9OF6YMv4LoLbgwek5ajYCw&oq=ikea+35+sqm+prototype+house&gs_lcp=Cgdnd3Mtd2l6EAw6BwgAEEcQsANQtzhYnU5gil1oAXACeACAAXiIAdwFkgEDNy4xmAEAoAEBqgEHZ3dzLXdpesgBCMABAQ&sclient=gws-wiz&ved=0ahUKEwjLwsTSsIXwAhWC7eAKHaQyCrsQ4dUDCA4
  660 KWh   room  heating                                  /  185 days/daies
1900 KWh   water heating                                  /  365 days/daies
1200 KWh   lights,appliances,cooking                /  365 days/daies
bringing this 1975 consumption numbers to 2021 TECHNICAL STANDART ( this is officially and by law : granted patent standart !) :
Target : energy source 100 W electric generator ( x 24 h generation) and electricity storage  2,4 KWh net
660   KWh  /C.O.P. 30  heat generator ,Wp ? = 22,0 KWh electric = 0,35 KWh/day coldest day peak
1900 KWh  / C.O.P. 30 heat generator ,Wp ? = 63,4 KWh electric = 0,175 KWh/day
1200 KWh lights,appliances,cooking to 1,5 KWh/day(LED,electric motor/heat-element,frequency controler improvement )
for the improvement as help the "intelligent household" appliances listening :
https://translate.google.com/translate?hl=de&sl=auto&tl=en&u=https%3A%2F%2Fwww.oeko-energie.de%2Fenergieberatung%2F
Total sum calculation :
0,35 KWh + 0,175 KWh + 1,5 KWh = +- 2 KWh electric consume per day
= 2,4 KWh electricity storage sufficient / 24 hours =         100 W e-generator sufficient
the last step : a flying autonomous house
for framework to be foldable and (trans-/fly-)portable as building
https://www.moma.org/collection/works/804        This 1,600-square-foot house weighed only three tons
https://karmod.eu/blog/versatile-foldable-building/
https://books.google.pt/books?id=Zs8DAAAAMBAJ&pg=PA20&lpg=PA20&dq=foldable+portable+building+kalinowski&source=bl&ots=IKxFTA8cXU&sig=ACfU3U1YU7mv9ih2jQbr4WP-3HU4S1qSyw&hl=de&sa=X&ved=2ahUKEwjA6b6k3YXwAhUI3xoKHfQkAaAQ6AEwCnoECBEQAw#v=onepage&q=foldable%20portable%20building%20kalinowski&f=false
https://www.youtube.com/watch?v=Lhhj5NWYosA
a platform,a drone, a jet belt structure :
Sonic wave powered aircraft - which burns any fuel and has vibration valve plate to generate thrust
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=DE&NR=2335220A1&KC=A1&FT=D&ND=3&date=19750130&DB=EPODOC&locale=en_EP
