Creating TPU Steven_Mark
Started by crashangel, September 06, 2019, 02:25:16 AM
crashangel
Turbo
Quote from: crashangel on November 03, 2019, 12:34:39 AM
Hi guys, I finished my tpu today .... It was hard work ... I used a 26 AWG aluminum wire. SM said that multiple wires would do better so instead of putting multiple wires into one to make the collector I created a collector with multiple layers of coiled wires overlapping each other .... as the wire is too small and coiled in a tube of plastic looked like a tape ... after the several layers of tape on top of each other I organized the wires and soldered them to become a collector ... and so did the 3 collectors .... put a kind of foam rubber to separate each collector from each other in place of cork ....
Well, now I have 3 input coils, 3 output coils, 3 input collectors and 3 output collectors ....
I would like to know how would you connect the collectors? Leave it all in one collector? I put a diode in the output and then turn it back on the input or some capacitor? I put a diode in the collectors input?
I kind of got lost now ... if anyone can help it would be great !!!
Thanks!
Well i can't help because you just did everything i advised not to start with.
What are your expectations ?
That it will somehow magically light up a light bulb ?
It doesn't matter how you connect it because any way will lead to the same outcome.
Thaelin
Turbo, you can only suggest. In the end, they will build it the  way they think it should be. Their nickle now.
I personally am starting at the beginning and trying to produce an input that will show a larger return. What I call step one. Steven gave many hints to how so on we go.
thay
onepower
Crashangel
QuoteWell, now I have 3 input coils, 3 output coils, 3 input collectors and 3 output collectors ....
It's easy to get lost and before we build something it should be clear in our mind what were building is supposed to do and how it is supposed to do it. Thus building comes after we have a theory of operation and after we have worked out how everything is connected and switched. Otherwise what were building is little more than an expensive paper weight.
If you could post a picture with all the connections labelled that might help.
crashangel
Ok, this is device!
we have one in and one out for each control coil and collecting coil ...
