Creating TPU Steven_Mark
Started by crashangel, September 06, 2019, 02:25:16 AM
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3330899&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
Venturi  ? Is the Biot-Savart law an electro-magnetic venturi velocity ( and pressure)  in-/ decreasing formula. ?
But : the Biot-Savart law also denominated : Ampere law and Laplace law. !
onepower
Zapnic
Quote"You know, it is very similar to the idea of a long garden hose.
Picture a hose with water in it.
If you pick up one end and move along the length of the hose you will
move the water constantly along in the direction you are moving.
You could also squeeze the hose in the direction to move the water
along as well.
You are correct and SM used this analogy many times when speaking about the TPU.
We could think of the conductor as a pipe containing our mobile electron fluid. Many people simply pump the electron fluid just like a hydraulic system so the input can never exceed the output for obvious reasons. They just keep on pumping and they just keep on failing because they do not know any different.
However in the real world we have external Magnetic and Electric fields which can act on our electron fluid. We also have internal molecular motion which when coordinated and directed could also act on our electron fluid. It does not matter how the force on the electron fluid is produced only that it is, to produce an electron current.
Turbo
Quote from: onepower on November 07, 2019, 10:51:37 AM
Yes i have always thought that the TPU would run on a Fluid.
In one of the video's i thought i have seen one dripping.
Do you have any idea where we can buy this 'Mobile Electron Fluid'  ?
Is it somehow related to Ferro Fluid ?
Many Thanks.
jojo500
leaf blowers only! and it must be gaspowered (2stroke only)
the dripping is unburned oil and fuel from the 2stroke. ::)
Quote from: Turbo on November 08, 2019, 03:30:47 AM
Many Thanks.
Turbo
Well if that is the case then it's a pity because 2 stroke engines were forbidden here some time ago.
