Creating TPU Steven_Mark
Started by crashangel, September 06, 2019, 02:25:16 AM
WhatIsIt
Quote from: Jeg on September 24, 2019, 02:36:33 PM
Turbo
Do you know what is the material that releases the electrons in sm's devices? A closed loop iron wire in parallel in between the collectors? Like in the photo above?
About radiated particles and catching them.
Poyint posted this Otto doc I never saw before.
Interesting read!
Maybe that picture above and Turbo are same principle?
Both catching radiated particles.
WhatIsIt
Turbo
Poynt99 posted this Otto doc I never saw before.
Interesting read!
Turbo
Quote from: forest on September 24, 2019, 01:56:25 PM
Turbo
Can you be precise in your statements ? Can you correct me ?
1) 3 control coils one on top of the other (circular rings each of smaller diameter) are used to create effect of radiation of "particles" which Otto described
2) 3 collector coils , each one around one control coil
3)  one collector coil on everything
collector coils are output coils and catch "particles"
is that the correct description ?
1. No not 3 control coils on top of the other.
It's 3 Collector coils on top of each other with control coils wound around each of the collector coils.
I would advice to firstly find the basic effect and once you understand that, scale it up,  just like Steven did it.
2.no it's the way around.
its 3 Collector coils with control coils around each.
3. the way around.
3 collector coils with control coils around each, and with control coils around all of them combined.
This is the ultimate design, a cyclotron,  its not the preferred choice to start with.
Again, the easiest way is to find the most basic effect and then try to scale it up by generating this basic effect inside of a strong magnetic field/ 'control' coil.
This can be on constantly like in a DC field, that is ok it just means that you start off with a very inefficient  setup.
Or you can use a magnet so that you don't have to worry so much about it but your way of working has to have a specific meaning to it.
You know what you are doing and why you are doing it at all times.
Step 1. Generate the kicks.
Which coil ?
Collector Coil.
How ?
Feed a Atomic resonance frequency into 'collector coil'
Kicks will start to emit perpendicularly out of the 'collector coil',  the basic effect.
(fe56 will transmutate into fe54 giving up excess electrons)
Want to SEE kicks ?  click here https://www.youtube.com/watch?v=VFVZU2YwwJ4
Description:
My units behave as though they are variable tuning devices, and we are tuning them to a frequency just like a radio.
The closer you get to the center frequency the more power you permit the collector to dissipate into a load.
You can begin to collect the current and dissipate it with no need for amplification because the signal source also becomes the feed for the power source and has the natural tendency to run with gain.
It is important that you note that you can never tune too closely to the exact frequencies of power conversion because the power received by the collector will instantly destroy it.
Step 2. Deflect these kicks into one direction to maximize potential on impact.
Which coil ?
Control Coil. (or permanent magnet)
How ?
Controllable DC feed, or slightly out of phase  / harmonic feed on the 'control coil' that is wound around the 'collector coil'
The field has to be strong just after the kicks are released to force them into direction to maximize potential upon impact.
The field strength is critical, too much will act as a break and prevent them from moving, too little and they will just fly through and out of your control coil.
Description:
You see, one little kick amounts to nothing.
However imagine if you had hundreds of thousands of little kicks combining into one big current kick . . .
Step 3. Collect.
Which coil?
Collector coil (and Control Coil.)
How?
If you made it here, you will know what to do, the next steps will follow naturally.
Deflection, again, but this time not to force direction but to force an END to it by dumping all of the available energy into the collector coil by a stronger magnetic pulse,  timings are critical and if correct you will observe the 'Big Kick'
Description:
The multiple frequencies traveling around the coils are of too high a frequency to provide for any motive effort.
They are only a means to achieve an end.
The multiple frequencies begin to feed themselves and the multiple kicks become a combined big kick.
I call it resonating.
So you know what to do, and how to do it.
Above all be safe.
You are working with radiation and it can harm you.
A perfectly tuned collector will keep most of the stuff inside, because most of the energy will be confined in the magnetic fields and converted into heat and electricity.
Not so when you are working on tuning a system where the kicks will fly all over the place.
I can recall day's where my eyes used to hurt badly, much like 'welders eyes' if someone is familiar with that, and it just didn't dawn upon me that i was constantly blasting my head and eyes with kicks, or better said, Cathode Rays.
I won't recommend building the entire thing at once.
Just start simple and take it one small step at a time, because its close to impossible to get all the necessary elements perfectly right the first time.
If you start with the basic bare bone effect the small kicks that amount to nothing, and then succeed to combine them into one big current kick, your are already in the Goldilocks zone.
My prediction is that the next decade, most appliances will be nuclear powered.
You will simply go to the store and buy safe and small 'nuclear grade' iron fuel rod's just like you buy batteries today and plug them into your devices.
The big difference is that these fuel rods last a very ,very long time.
You won't have to refuel or charge your car or cellphone, ever.
I also thought it was a bit IRONic to conclude that we replace and throw out old batteries when we think that they are depleted, while their iron shell holds enough energy to still deliver a million fold in nuclear electricity, then what the cell just had produced by chemical means....
Talking about throwing out the baby with the bathwater  ::)
Turbo
Turbo
Iron at first and apparently later he found how to do it with other materials too.
Jeg
Turbo
Thanks a lot for the directives. Much apprciated. ;)
