Wireless energy transfer experiments ,Builders board
Started by ramset, September 18, 2019, 09:15:01 AM
r2fpl
I wrote earlier that for transmission through the earth cavity, Tesla used high energy to stimulate the resonance cavity. The minimum value given is 75kW. Maybe it's a way of implementation because we don't want to make a wave, just connect to it.
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Hanna+Albert+awad&IN=&CPC=&IC=
Point 6. ...... a motor which is driven......
           7.  Vehicle driven above ground
The less power need : energy transmission and receiving. : " magnet/capacitor" Earth
        Prof. Dr. Ehrenhaft studies
stivep
Jimboot
Moderators please remove if to OT.
I'm curious about a power supply that I have used on my coils.
On the very long list of things I don't understand. I've been trying different power supplies with my Zenneck coils experiment. I don't understand how this selenium rectifier is delivering results that a power diode does not. [/size]I'm measuring the 16VAC output of the transformer in parallel to the rectifier.The circuit only oscillates when the rectifier is in the circuit.The DC output on a DMM is around 8V or 16VAC on same DMM. It gets better results than by DC power supply at 12VDC . Stronger field more plasma etc.
With the dc supply it takes at least 12v for oscillations 150ma. Continuous oscillation. With half rectified ac nothing on other adapters or the the power supply above. It's only when the rectifier is part of the circuit. I see 50hz flickering when activated via the rectifier and 100ma current draw.
vid  https://youtu.be/_odJBpkGfrw
shylo
Hi Jim,
I'm very limited when it comes to electronics,but don't you need 4 diodes to make a bridge rectifier?
artv
