Wireless energy transfer experiments ,Builders board
Started by ramset, September 18, 2019, 09:15:01 AM
stivep
Few links allowing you to understand better:
link#1.
Explanation of Dr Corum from Viziv use of Zenneck wave from the perspective of?Zenneck wave
But prospected  by use of much higher  electromagnetic  waves - light.
it is analyzed in quora
note:
you must click: Continue Reading
How does the Tesla tower of Viziv Technologies work?
https://www.quora.com/How-does-the-Tesla-tower-of-Viziv-Technologies-work
Wesley
stivep
link#2
This is some sort of  information exposing - what is   being  false  or  exaggerated and what is not :
in regards to strange looking Russian structure  by some assigned to Tesla coil
https://www.slavorum.org/legendary-tesla-towers-are-operational-in-russia/
https://www.youtube.com/watch?v=gFQkb8O0CZM
Note:
Please go down  of the page to :
Chuck Ruff   8 months ago
QuoteFirst, these are nothing to do with anything Tesla did.
The high voltages are developed in a completely different way than from a Tesla Coil.
The imposing looking structures on either end of the field are not the marx generators.
One, the smaller of the two, is the 3 phase, full wave rectifier stack that changes the
power from a distant power plant to DC energy.
It provides very high voltage DC energy to the other similar looking structure, which is nothing
more than a voltage regulator and switching system to fire the generator.
The actual marx generator is the tower between them. It gets the least attention because
it's not as menacing looking as the other two structures.
Its purpose was to test aircraft assemblies for EMP hardening. Obviously you "load" a small aircraft or model for testing.
Truthfully, this is not a very good way to test for EMP hardening because there is very little high power microwave energy
generated it this way.
On the other hand it is fine for testing for lightning hardening.
This facility is pointed out as an example of more advanced sciences developed by the Soviet era, when in fact, in the
United States when EMP hardening is tested it is in a machine that generates an actual EMP pulse without high voltage discharges,
actually, much more advanced than using a huge inefficient marx generator. It is also much, much cheaper to run as well.
They don't get much attention because they don't use huge menacing looking structures and lightning bolt sized sparks to execute the test.
This does not harvest lightning, it generates it artificially. Second, it is also not an attempt to create a directed energy weapon as proposed by others.
I hope this clears up any inaccuracies in the original article, although I admit, much less dramatic sounding, considering it would never work for it's intended purpose.
I propose that is the real reason it was abandoned.
in this article  gentleman Marin Soljačić
is mentioned with
Quotefirst efficient non-radiative power transfer
and
QuoteUS$20 million grant from the U.S. Department of Energy,
https://en.wikipedia.org/wiki/Marin_Solja%C4%8Di%C4%87
and known for his work  in solitons
to find why it is important go to link #7 at the bottom of the page
Wesley
stivep
link#3
Quite intensive and in some point dramatic discussion about:
Viziv, Zenneck Wave,
wave properties in comparison to  laser,
Near Field and inverse square law
Although  it is easy  text , -for right readier it is good entertainment.
https://hardware.slashdot.org/story/19/02/10/0615248/ask-slashdot-could-nikola-teslas-wardenclyffe-tower-have-worked
for these who wants easier controversy based on historical perspective  go here
https://www.pbs.org/tesla/dis/responses.html
QuoteResponse
by Jim Hardesty
Because you seem to have considerable knowledge of the subject, and particularly of Maxwell's equations,
I will direct you to a very important book called Wireless Telegraphy by Dr. J. Zenneck (New York: McGraw-Hill, 1915). In Chapter 10,
"Propagation of the Waves Over the Earth's Surface," Zenneck provided some very useful information about ground waves.
Tesla indicated that Zenneck's ground wave was the non-Hertzian wave he was talking about.
The Zenneck-Sommerfeld solution to Maxwell's equations is another area for you to check.
It is known that one of the books that Tesla's most used was a copy of Maxwell's original work.
Because much of that appears in quaterions, one can assume that Tesla had considerable
familiarity with them.
I will leave you with this. Have fun!
Wesley
stivep
link#4
Here  we have
WirelessPower Transmission Future as Showcased
in Nikola Tesla's Electricity Unplugged
Thomas Valone, Ph.D., P.E.
Integrity Research Institute, Beltsville MD 20705
Start reading from page 10
https://www.integrityresearchinstitute.org/IRIANNUAL2016.pdf
Quote"All  that  is  necessary,"  says  Corum,  "is  that  his  transmitter  power  and carrier frequency be capable of round-the-world propagation.
" In fact, Tesla stated, "With my transmitter I actually sent electrical vibrations around the world and received them again,
and I then went on to develop my machinery" (L.A. Times, Dec., 1904), which was verified by Dr Corum.
QuoteThe power loss experienced by this pulsed, electrostatic discharge mode of propagation was less than 5% over 25,000  miles.
Dr.  Van  Voorhies  says,  "...path  losses  are 0.25  dB/Mm  at  10  Hz",
which  often  is  difficult  for  engineers  to  believe, - For these who  are  used  to  transverse  waves,  a  resistive  medium,
and  line-of-sight  propagation  modes
And some snack,
something easy -  for easy go.. people:
QuoteWhen launched, the Zenneck Surface Wave literally envelops the planet like a balloon,
enabling transmitter probes to be placed anywhere power can be generated and receivers
to be placed anywhere power is needed.
https://swling.com/blog/2018/10/scientists-studying-wireless-electric-transmission-in-central-texas/
Wesley
stivep
link#5
http://www.institutotesla.org/pdf/TESLA-THEORY-1.pdf
nice pictures of original pages
Text loooong... in English
I didn't read it yet
but for some reason ends with Russian
......................Ok I think I know what is going on.
they use Russian references
QuoteReferences  .
1. B. Rzhonsnitsky,
N.Tesla, Moscow, 1959.  2. I.Tamm,
The bases of the electric theory, Moscow, Leningrad, 1949.  3.
Kessenikh, Propagation of radio wave, Moscow, 1952.
So it looks like it is "Tesla  from Russian point of view"
Can be interesting .
Let me know if it has any value.
if not I'll  remove  it.
Wesley
Wesley
