This forum is turning into trash
Started by ARMCORTEX, September 25, 2019, 04:33:34 PM
rakarskiy
Quote from: onepower on November 02, 2019, 06:38:37 PM
As well every true genius involved in FE followed a specific learning curve. First FE effects, then FE devices, then the transmutation of matter and then a select few graduated to anti-gravity devices and other external effects such as weather modification. Therefore there must be a direct link between FE and the external environment.
I dare say.
There are at least two types of electrical power generation devices.  Devices, the first type-which uses the potential of the external environment (conversion of various fuels or capture potential, external forces).
Devices of the second type-which use the potential of the artificially created internal environment (this is the upper type, which has an engineering solution, which is based on the cyclic operation of the Archimedes lever, centrifugal forces, etc.also devices configured to perform the similarity of the Archimedes lever, but in magnetism and it is not mechanics).
I am interested in the second type of devices, which is the desired for OU.
A small video, appropriate subjects. The author claims that the technology is from the past of the Communist Soviet Union.
https://www.youtube.com/watch?v=2SEAZPmnEa0
Turbo
Well that gray tube looks like an open air Crooks tube and i can see the same thing the bombardment of an element with high energetic particles but it also looks like the crudest way or a brute force way to do it, just generate as much sparks as possible to get some of it just right.
Of course this ties into gravity because its the direct conversion of matter into energy so the fuel element will lose weight and whoever say's that is not gravity related  ::)
DavidWolff
Quote from: Turbo on November 03, 2019, 08:14:59 AM
Wrong gravity is the most understood can of worms going it's about electrical charge, as above so below the egeptions discovered that hundreds if not thousands of years ago.
the planet is like a huge atom with the electron which is the same way the atom is held together around its center o0nce you got to the earths center you would lose the pull.
Turbo
Quote from: DavidWolff on November 03, 2019, 08:58:39 AM
Explain to me how there is no link between the amount of mass and gravity.
Explain to me how your car with a filled gas tank is equally heavy as your car with an empty gas tank.
Are you sure about that ?
Turbo
This forum has always been trash.
It's just getting worse.
To theorize about the unknowns is one thing.
But people even start to debate the already well known and established things.
It can not possibly get and worse than that.
