This forum is turning into trash
Started by ARMCORTEX, September 25, 2019, 04:33:34 PM
kolbacict
Quote from: DavidWolff on November 03, 2019, 08:58:39 AM
  o0nce you got to the earths center you would lose the pull.
for this you need to get there (in the center)?
to do the work.
onepower
Turbo
QuoteThis forum has always been trash.
It's just getting worse.
To theorize about the unknowns is one thing.
But people even start to debate the already well known and established things.
It can not possibly get and worse than that.
Agreed, and most people cannot even grasp what is already known and found in most textbooks let alone moving the conversation forward. Now we have the flat Earther's and the Trumper's with there nonsensical alternative facts. It could hardly get any more screwed up but somehow... we know it will.
DavidWolff
Yes, your absolutly right not one of the guys or gals on this forum has shown any real clue as to how it all works since Stefan brought in that (Philistine) guy you all know who! In truth, Henry Moray was a bloody good engineer and futuristic design super brain who knew his stuff who was pestered by political moronic peasants who destroyed all his work in the end over ignorance and stole all his work like semiconductors and his plasmer accelerator valve which is very close to the magnetron used in microwave cookers today.
It' s a shit situation the way it's going and won't change for sure well not here.
Turbo
Not for as long as you will keep posting your opinions.
AlienGrey
Quote from: skywatcher on November 01, 2019, 07:17:59 AM
My point is:
There are people claiming 'overunity exists' and they are telling stories about working magnet motors, water-powered cars, and other types of devices... but when you want real proof, when you want so see it working, when you want to see construction plans, you get NOTHING. This forum is full of stuff like this, and it is repeating over and over again, but there was never a working device which could be successfully reproduced by others.  NEVER.
When I look at Moray King I also see nothing which could be actually used. He is doing research (which of course is good) and maybe he has discovered some effects which can not be easily explained (which you will always find when you are doing experiments of any kind) but as far as I could see he also has nothing which actually works and can be reproduced.
Well It depends on what you look for and where you look and what keywords you using your vocabulary is just free energy what do you expect, I'm not trying to be evasive but you can only use this stuff for educational ends producing it will get you and others into trouble.
BOTH Dr. Stiffler and Wesley know more than most but I don't see any of them or our host  Steffan putting themselves at risk so please search your self on this subject I'm sure you will find stuff to help you out by READING!
HAPPY DAYS BUD!
Turbo  Re your comment apers to contradict itself See Quote
you make a statement and then jump to a conclusion
So i will tell you my findings on that PAGD.
The electrodes deteriorated and it would only run for a limited amount of time before they need a replacement.
This means they or the material itself is the fuel that gets 'burned'
And the energy that is released is then channeled or focused by the strong electric field component.
It could be a crude way and there might be a more efficient way's to generate the same effects.
~>I'm sure i could think of another 2 ways of doing this but the way you are suggesting it depends on the material and the only way back at the start that worked and was exploited to its limit. <
And it is known that elements can undergo transmutation when they are bombarded by high energetic particles of a specific energy level.
How about your self making such a device your self a test rig to display your findings you're talking about i'm sure the TPU uses this same invention in fact iknow it does.
Good luck.
