2Sgen "Cook" resonator
Started by synchro1, October 07, 2019, 11:34:38 AM
synchro1
A grounded coil wth an antenna and capacitor in between will build a charge on the positive electrode. A negative charge will match it from the Earth on the negative electrode. This charge is proportional to the area and height of the antenna.
When the positive electrode of the receiver capacitor is charged by the transmission wave, it has the same effect as raising or enlarging the antenna. The positive charge is elevated and is matched by a negative charge that is generated by the Earth's spinning molten iron core.
The rise in voltage at frequency is a scaler or longitudinal wave that has no fixed location. The "Earth Ground" can be anywhere; The actual Ground is in "counter space".
synchro1
        Mars Rover
NASA could transmit power instantly to the Mars Rover with double tuners. Raising the voltage in the transmitter tuner would result in an instantaneous rise in voltage in the receiver tuned to transmitter "Q" on the Planet Mars. The problem is that everyone could receive free power here on our home Plant Earth along with the Mars Rover with properly tuned frequency receivers!
kolbacict
synchro1
Quote from: kolbacict on November 02, 2019, 11:39:33 AM
https://www.youtube.com/watch?v=bbpso7zAlvU
Why didn't I succeed, what am I doing wrong?
You would need to remove the resistor and add two variable capacitors to tune for sufficient "Q"; Then you could transmit an intercontinental short wave broadcast signal with a sine wave beat frequency or tune a longitudinal wave that would stand still vertically on the scope and transmit power like quantum entanglement when the receiver was at the same resonant frequency.
A rise in voltage would be detectable by a receiver in a hidden Universe beyond the reach of light!
You can communicate Inter-Dimensionally with the "Multi Universes" if you simply remove the resistor!
Placing a cooper "U" between the capacitors would light bulbs with cold electricity like Tesla's "Hairpin Circuit".
You built a cool CB radio.
Thanks for the excellent demonstration video.
kolbacict
Why are you so ... I was hoping there would be something unusual.
It's cruel. :)
