Thanks to ALL for your help!!
2Sgen "Cook" resonator
Started by synchro1, October 07, 2019, 11:34:38 AM
synchro1
                                                              2Sgen looper
Connecting a fixed value capacitor to JLN's nano perm toroid coil pictured above and a variable capacitor to his inductivly coupled output coil would allow us to tune them as a resonator with a sufficiently high "Q" to generate enough voltage gain to return power to source. Loosening the coupling can regulate the output.
An SJR3 transistor would run it fine.
synchro1
        Earth resonance
My quadfilar "Spiral Toroid" coil has been resonating for over six years. Two bifilars of identical inductance. I believe the resonating frequency is driven by the Earth's magnetic field.
I reasoned that every resonate "Q" value frequency between LC tanks of identical inductances must share the frequency of this magnetic resonance of the Planet and be a constant value.
This apparently creates a strong carrier wave for every high frequency radio broadcast. The magnetic power band is right at the lower edge of the radio frequency.
All Double tuner "Q" must be the same frequency as Earth's magnetic field resonance. How could it be other wise?
synchro1
The Earth is a self tuning resonator that works just like our double tuner; Here are the frequencies:
synchro1
Here's Tesla's scaled up version: This resonator tunes itself to Earth's background frequency naturally, because the oscillation frequency is constant!
That means the 2Sgen double tuner would resonate at the same frequency as Tesla's Wardencliff.
This means it would broadcast the power to a receiver resonator!
Gotoluc demonstrates multiple receivers from a Tesla broadcaster with no rise in input!
synchro1
        Earth resonance
The Earth has capacitance in it's crust and induction in it's iron core. The Sun charges the dielectric field. The Van Allen belt is the same plasma that appears in the spark gap of an LC tank. This results in a frequency that triples in the cavities, 7, 14, 21--
Double LC tank tuner "Q" is a harmonic multiple of Earth's resonant frequency!
Tesla's electric Packard had a vacuum tube resonator that charged the car's battery at Earth resonant frequency.
Tesla didn't have nanoperm and neodymium!
The 2Sgen resonator can self loop and power our appliances with Quadfilar receiving antennas with background carrier wave reinforcement from Earth's natural resonance!
