Getting energy from asymmetry of the magnetic field experiment
Started by ayeaye, November 19, 2019, 11:10:15 AM
ayeaye
It's a kind of tricky to put the big magnet under an angle there, so that also the angle can be adjusted. Considering using cardboard. On the figure below, the height is adjusted by layers of cardboard. I use mounting tape to attach everything, that makes it somehow adjustable, though not that easy either. In my experiment, i used matchboxes and cardboard from matchboxes, in a rather improvised way. There may be easier ways, like a rectangular magnet may be directly glued to box, another question is how to change its angle then, just remove the glue and glue again? I just showed a kind of way how i did it, i don't say that it's necessarily the best.
ayeaye
Not measurable force that is, you can sure feel the force by hand, but the scales show nothing, don't even visibly move. I have seen it several times, hand is not good enough to determine the strength of the force.
This lid of the box and cardboard beneath the small magnet, were really very thin, couldn't draw them as thin as they were.
To measure all forces, i don't know. Cardboard both beneath and above the small magnet maybe. Then some thin transparent plastic something, on the lid, at some height. A thread comes from the small magnet, and it moves beneath it. So that when the vertical force goes up instead of down, then it moves on that plastic above. Maybe it works somehow like that. Maybe put it there only temporarily, only to measure the forces when the force goes up, maybe even not necessary to measure them more. Sure a bit more to do, and think how. Possible of course to put some surface on it temporarily, and hold it by hand. Just what i can figure.
You may start to make this test device even when the scales have not yet arrived, a bit to tinker, though not that much.
telecom
I placed everything on a side, rather than vertical.
Also used an aluminum channel to guide a smaller magnet.
My camera stopped working, will try fixing and sending a shot.
ayeaye
Great.
You can get cameras from ebay or ali express, for $2, something. I have these cameras, so i never have a problem that i have no camera. But then, these cameras are not very good. Also the camera that i used for my video was not very good.
ayeaye
One thing that shows overunity, is acceleration. That is, if there is initially no force to the magnet, and it goes through all the field getting speed, then the field can do continuous work. If friction is low enough. The only way it can be seen, is when the magnet enters the field with a certain speed, and its speed is increased when it exits the field. Because, when initially there is no force, then nothing other than speed can make the magnet to enter the field.
I saw how one released a magnet in the trigate, it accelerated, and this supposed to show that trigate has overunity. That was the most disgusting cheat. If you put a magnet in the field of another magnet so that it repels, and release it, then it accelerates. It showed only that and nothing more. The necessary condition for overunity in that case, is no initial force.
To say that again, i used matchboxes in my experiment, to put a big magnet under an angle vertically. The key is that there has to be three points of support, in such a way that when trying to move the upper corner of the magnet horizontally, there is enough resistance in both directions.
