Getting energy from asymmetry of the magnetic field experiment
Started by ayeaye, November 19, 2019, 11:10:15 AM
telecom
Quote from: ayeaye on January 06, 2020, 06:03:37 PM
Distances moved, and for each distance the force to the magnet. A distance multiplied by that force is energy. Calculate energy for all distances moved, and sum all these energies, this is energy at one side.
Ok, that drawing again, it didn't look so nice previous time. The small magnet there is at the neutral position. Left and right from the neutral position on that drawing, is what i mean by left and right. I found by measurements that energy is greater at the left side. 13.14 mJ at the left side and 5.15 mJ at the right side (without friction).
Just to clarify, on your diagram, a smaller magnet is a magnet or a nut?
Can you plz provide approximate dimensions of your setup?
Thanks.
ayeaye
Quote from: telecom on January 08, 2020, 11:01:30 PM
Thanks.
Sure. The setup is as on the drawing below.
The small magnet is two ceramic disc magnets 10 mm in diameter and 5 mm thick, one on the other, on a small piece of thin cardboard.
The big magnet below is 8 ceramic disc magnets 25 mm in diameter and 5 mm thick, one on the other.
sm0ky2
ayeaye
kolbacict
To make it work without a support:
Place two more ring magnets outside of each end
to do the opposite of what the first sets do.
This will stabilize the rotor on the outside and keep it
from flying off.
We tried it before, now I have tried it again. It does not hold, it sticks.It has been manufactured for two years
.Jumps off and attracts.Only a gyroscope or use electricity.
