Getting energy from asymmetry of the magnetic field experiment
Started by ayeaye, November 19, 2019, 11:10:15 AM
ayeaye
Quote from: telecom on January 21, 2020, 04:14:55 PM
Yes, exactly, small magnet is being repelled, but it has not only vertical,
but a horizontal vector as well, IMHO.
Yes, at some distance there certainly is some horizontal vector of that. But i tried to measure that horizontal component every way i could, i couldn't find any measurable force. One way is to put some surface on the small magnet, as it is repelled, and no longer stays on the surface below, to be able to measure that horizontal component. There is certainly some horizontal force in that case, but it may not be strong enough, so that the spring scales can measure.
ayeaye
Telecom, good if you would replicate, very important. Fish scales, spring scales, but maybe even the best is weight over a pulley. Somewhat difficult to make though, i think i did it in the simplest way.
telecom
I will order digital scale on Amazon.
Like those:
https://www.amazon.ca/AMPPHY-Electronic-Portable-Hanging-Luggage
Meanwhile was playing with different angles of the large magnet.
I've noticed that small magnet produces quite a lot of vertical force
on the way out.
It can be added to the output through some kind of a mechanical leverage,
I think.
telecom
I have an idea to connect two of these setups back to back, in such a way,
that while one attracts from the left, another from the right.
If the left one has more power, we should see it pulling more.
What do you think?
ayeaye
Quote from: telecom on January 22, 2020, 05:53:47 PM
What do you think?
Force? See my graph above. The all matter is, force appears to be less at the left side, and more at the right side. Yet at the left side this force goes to much longer distance than at the right side, and as the result the energy at the left side is greater than at the right side. The energy is the area under the curve, it is force multiplied by distance, or sum of these for several small distances.
There, a single thing that really may show the most, is how far the force goes at the left side, and at the right side.
