MECHANICAL LEVERAGE
Started by seychelles, November 26, 2019, 06:46:11 AM
seychelles
HI ALL I AM A CAP LOCK ADDICT SO PLEASE BEAR WITH ME.
AS PER THIS DIAGRAM WE SHOULD HAVE AT LEAST 200 % overunity.
citfta
It appears that you don't understand basic physics.  A lever converts force into distance or vice versa.  It does not produce over unity.  In your example the end of the lever connected to the generator will have 200 % less force than the end connected to the motor.  And that end will have to move in a much bigger circle than what you have drawn.
seychelles
seychelles
seychelles
Showing results for LEVER PHYSICS
Search instead for LEVER PHISICS
Search Results
Featured snippet from the web
Image result for LEVER PHYSICS
www.youtube.com
A lever is a rigid body capable of rotating on a point on itself. ... A lever amplifies an input force to provide a greater output force, which is said to provide leverage. The ratio of the output force to the input force is the mechanical advantage of the lever.
