"Quantum Receiver".
Started by synchro1, December 06, 2019, 06:08:06 AM
skywatcher
Quote from: Toolofcortex on December 06, 2019, 12:55:51 PM
Synchro seems to know his theory, why dont you people listen to the man and build?
To be honest, i don't understand his theory well enough to be able to build anything.   :-\
Some more info about this 13.56 MHz frequency would be helpful... maybe some concrete experiment which shows some effects and can be replicated.
synchro1
Two Neo magnet tubes with their static fields in resonance at 13.56 Mhz, would Quantuum couple and open a pathway for the transmission of power and signal data through counter space. Two crystal oscillators and two tube magnets would be able to transfer power and data instantly from Earth to Mars if they did it across a test bench.
Dr. Stiffler privately disclosed to me and a few others that he had indeed confirmed this "Quantum Link", but chose to keep it guarded from the public to avoid stress.
skywatcher
Quote from: synchro1 on December 06, 2019, 03:23:16 PM
Two Neo magnet tubes with their static fields in resonance at 13.56 Mhz, would Quantuum couple and open a pathway for the transmission of power and signal data. Two crystal oscillators and two tube magnets would be able to transfer power and data instantly from Earth to Mars if they did it across a test bench.
Did you confirm this by own experiments (not to Mars, across the bench would be enough for the moment  ;) ) ?
What do you mean by 'neo magnet tube' ?  A tube-shaped neo magnet with one pole inside and the other pole on the outside ?
How are the crystal oscillators connected to the magnets ?
synchro1
Quote from: skywatcher on December 06, 2019, 03:31:29 PM
There is no electrical connection between the oscillator and the magnet, only capacitive. Tubes are longer ring magnets. Any Neo magnet will work. Lidmotor has a few good videos.
I never tested it. I'm setting up to run my first video.
Stiffer never discribed his set up, but modulating the resonant wave would carry the signal .
