Thanks to ALL for your help!!
"Quantum Receiver".
Started by synchro1, December 06, 2019, 06:08:06 AM
synchro1
                                                         Unified field theory of Stienmetz:
The "Galaxy Field" has an LC resonance where the Neutron Star at the center acts as an Inductor absorbing energy. Cosmic radiation is the Energy from the transmutation at the dark matter boundary layer, this frequency is 13.56 Mhz.
Matter and Energy can neither be created nor destroyed. They exist as equal. They transition at the rate of E=MC2. This transition takes place both between the boundary layer of the Neo magnet and the perimeter of infinite Energy and Infinite Mass at the same frequency of 13.56. The Plenum!
Stienmetz fed Einstein that equation based based his LC theory and the "Planck Constant". Dr. Stiffer discovered this frequency!
Tincan'sful of Coladas said piezo not pedo.
synchro1
13.56 divided by 52 equals .260. The days in the sacred Mayen Year. "The Maya sacred calendar is called Tzolk'in in Yucatec Mayan and Chol Q'ij in ... in combination with the numbers 1 to 13, and produces 260 unique days". The Mayen Calendar is calibrated in units that are a pulse beat of the Galaxy.
"Venus can be seen from Earth as a small black dot moving across the face of the Sun. The duration of such transits is usually several hours (the transit of 2012 lasted 6 hours and 40 minutes). A transit is similar to a solar eclipse by the Moon". One fourth an Earth revolution.
The Lunar cycle is 13 months of 364 days: 4 thirteens are 52: 20 thirteens are 260.
The Planetary orbit cycles are a harmonic of the Galatic LC frequency. This is "Mayan Cosmology". Poker deck.
These Cosmic harmonic conjunctions are not a coincidence. The Harmonic conjunction of of the solar transit of Venus with, Earth's rotation rate, Luner revoloutions and Eclipse frequencies. These carefully recorded observations helped the Mayans redact this "52 Loom factor" as a Roundoff.
synchro1
The Quantum grid is the Loom of Maya.
synchro1
The Earth has a black hole in the center. This "Black Hole" is connected to the "Black Hole" in the center of the Galaxy and the Sun by a Hperdimensional force. This "Earth Core Black Hole" generates a closeted base frequency from the boundary layer between dark matter inside the Earth's core like our Heavenly Father Hu'Nobku. The "Atun of the Maya". (Regaring the subject with reverence)
13.56 Mhz is a "Quantum Constatnt", not just one frequency among others.
synchro1
Stiffer started resonating the static field of coils with our Earth ground frequency and discharging the increased capacitance into LED's to generate electricity.
Next, he resonated a deeper nested "Ground Frequency" that he discovered, from a more powerfull Gravity source within the Earth's center. Lidmotor amplfied it by Crystal.
Tesla's (wireless theory) can be applied to transmit power and signals through this deeper ground. The "Quanta".
Lidmotor amplified this frequency with a Crystal Oscillator. He succeeded at this. He could blink it and send a Morse code signal instantly to Mars with a receiver. His wireless power is traveling through the Quanta layer, not the Earth static field like Tesla's.
