"Quantum Receiver".
Started by synchro1, December 06, 2019, 06:08:06 AM
synchro1
To burn Salt Water like Dr. Kanzius, you would need to include a high voltage generator in the circuit. Lidmotor is Hydrolyzing with 12 volts. Connecting a power transistor between the Crystal and an Ignition coil would boost the potential to 40,000 Volts. This HV pulse would cause Salt Water to burn at that frequency.
Let me reemphasize; Dr. Stiffler noticed this frequency naturally occurring in the background with his Oscillascope. Got it! From Outer Space, not the Ocean, Understand?
sm0ky2
Quote from: synchro1 on December 11, 2019, 12:16:21 PM
Micro-wave frequency is 300 Mhz to 300 Ghz. Plank calculated the speed of light at 300,000 M/S and the highest frequency from the same constant. Light is supported in a field of infinite energy that cradle's it in a carrier frequency. Also, we are attracted by Gravity from an unseen source too far for light to travel yet connected.
The theoretical max freq. was based on the same constant we named after him.
Our thinking was this is the shortest possible wavelength.
We have since then found shorter wavelengths and thus higher frequencies
synchro1
Quote from: sm0ky2 on December 11, 2019, 09:52:13 PM
@smOky2,
The thumb of measure blocks the view. We would have a "Translational Frequency" in (Quarts?). From the reference of any number base. 52 is the Co-efficient of any Odd system and 76 (76 is an automorphic number) Even. Martin Heidigger wrote a track on Metaphysics and the law of Identity, the origin of Mathematics. Watch this video, it's pertinent.
E. W. Davis and H. E. Puthoff, "On extracting energy from the quantum vacuum,"  It's already here!
https://www.youtube.com/watch?v=klXj198vY4A
synchro1
Dr. Puthoff told Dr. Greer he and his family would be killed if he tried to bring this "Quantum Energy from the Vacuum" out; Well Here's Jonny!
All anyone needs to do is to wrap a single wire air core coil with a (SRF) of 13.56 and they can help themselves. It really doesn't take that much What's the big deal?
Dr. Stiffler shows that you can place multiple diode rings in adjacency to the resonating clip wire and generate any amount of electrical power!
We have a new word: 13.52 is an "Automorphic Frequeny". The Ideal Frequency of 13.52 squared matches the last digit of itself.
synchro1
The point I'm making that's different from Dr. Greer's is that if we receive power from the Quantum we can use that medium to transmit all our information too. A Quantum Web!
Let's say you had a diode ring and I had a diode ring; Suppose I could receive a single blink signal from you through it. I could receive an A.M. broadcast signal longitudinally next with a quick fix.
A Quantum "Ham Radio" club would eventually replace the entire linear Grid.
