Intercalated graphite carries a resting voltage without giving a charge.
Started by Jimboot, December 24, 2019, 05:29:23 PM
kajunbee
A couple things you might keep track of is temp and humidity. It is socked in fog where I'm at so moisture in the air may have some effect.
Jimboot
Quote from: kajunbee on December 26, 2019, 07:45:10 AM
I have a barometer in the shed so that's a very good test. Thanks. I should get some good transients of the next couple of days. It has felt more humid but I have not measured it. I should add though if I hit with a torch voltage will increase.
kajunbee
I had to find out for myself how much moisture content effects the measurements. These are the results from 3 runs. I started each run with saturated separator of salt solution. I then popped the separator in microwave in ten second intervals and recorded voltage of assembled cell.
kajunbee
I just realized that I'm not taking into account the contact when the separator drys. It becomes rigid and wrinkled and is effecting the readings. I'll try to clamp it someway before taking measurements.
