Simple and powerful principle
Started by nix85, March 17, 2020, 07:30:59 PM
Floor
So....
I don't think at all, that we should "give up" on looking at or for over untiy or free energy or
alternative energy designs and so on.
I say let's keep on keepen on !
best wishes to all
      floor
    ps
nice posts / links LankaIV
nix85
Quote from: andrea on January 24, 2021, 03:01:39 AM
Where is the overunity?
The gain that you could get by transforming the potential energy of the object when it's lifted to the top, is the same of the energy that you have to spend for refill with the same quantity of water the top of the "tower", before to open the valves and make the system start again.
The object, lifting up in the column of water, make an identical amount of water to go down on the bottom. The water that is going down has a specific weight that is the same,  no, a little more of the object's weight (otherwise the object wouldn't lift). When you close the valves to recover the object in the upper side (and then maybe make it fall to move a generator transforming the Ep in real energy ecc ecc), instead of the object remains an equal amount of air. How do you refill that, without consuming the same quantity of energy?
I hope I am wrong, I really would like to see an overunity sample. So please answer me.
Interesting principle, indeed.
Bye
Wrong, you don't have to refill, only open and close 2 valves. Any weight to any height.
forest
Right.Open two valves and a little push then the problem might be to fall back this weight to the bottom.
nix85
Why would that be a problem, once on top you just got to lift it over the pool wall. Small electric motor can do that and could be automated.
nix85
interesting similar principle with compressed air
as u can see air is injected at the bottom
and immediately cylinders are rotated trapping the air
making em buoyant, at the top air is released
https://youtu.be/7-5qd7bEiqA?t=752
ofc, again, i don't suggest anyone follow this
primitive principle with so many better ones out there
