All Permanent Magnet Motor
Started by magnetman12003, March 28, 2020, 03:43:49 PM
synchro1
Quote from: magnetman12003 on May 28, 2020, 08:58:09 PM
After thinking it over I plan to show the working motor only after I patent it.
I already gave out enough information about it if someone decides to use the SLING METHOD of making it. It's not as simple as it looks to be as anyone attempting to replicate it will find out.
But you will see the light after you play with it a while.
Balk!
conradelektro
Oh, one wants to patent it, surprise, surprise!
There are hundreds of permanent magnet motor patents (the allegedly self turning kind, without any other power source, the impossible ones) and none of them really works.
Therefore take note: patenting something does not make it work and it definitely is no proof that it works.
The patent offices of this world do not check whether something works and the requirement that something is not allowed to contradict current wisdom is handled in a very lax way. As long as you pay the fees, everything goes, it is a matter of wording.
O.k. discussion is over, spare us the cryptic hints.
Greetings, Conrad
citfta
I was really afraid this was where this thread was going.  I have been experimenting for the last couple of years with magnet interactions.  And I just did not see how this could work.  So now the usual excuse.  "I have shown you enough. Now I am going to get rich."
For anyone interested in some real experiments with magnets but no claims of OU you can watch videos of my progress in Floor's builders section in the thread "Possible magnet motor idea experiments".  Some of the videos show some interesting interactions that might surprise you.
Carroll
Magluvin
Holding the weighted bolt against the angled magnet at or near 45deg by hand, its like lifting a 10ft 4x4 by one end while the other end digs into the ground, in the similar direction that the wheel seems to move.  So as you lift the end of the long board and try to stand it upright, it digs into the dirt more and more as you lift the one end. Now with that same 4x4 10ft board, put a roller skate under the other end and try to stand up the board from the other end.   ;)
Sorry my fellow mag man, it was your hand interaction that had direct affect on the wheel turning. But if you insist on a pat, you can do a little studying and draw up your own prov pat(after doing a pat search to see if it has already been pat) and it only cost you $75. If it is granted, you are covered for 1 year.
Mags
citfta
Hi Mags,
That's a very good analogy of what is going on with his magmotor.
