All Permanent Magnet Motor
Started by magnetman12003, March 28, 2020, 03:43:49 PM
ayeaye
Quote from: Magluvin on May 30, 2020, 08:10:56 PM
magnets above the speaker magnet could be mounted directly to the speaker magnet and it could all spin as one, as per the Faraday paradox
No way.
I also don't think there is any fancy explanation to all these bolts, etc, of the 45 degree magnets. I think the magnetic field is just uneven, and it needs flexibility to smoothen it, as overcoming friction is so difficult to achieve that every small thing matters. But i think these are just technical details, it is in essence a 45 degree magnet moving in the field of the pole of the ring magnet. Nothing more fancy, but the overunity due to asymmetry of the field is an interesting physical phenomenon sure.
kolbacict
And if magnets at an angle of 45 are replaced by amazing banana magnets?
Airstriker
Quote from: magnetman12003 on May 28, 2020, 08:58:09 PM
After thinking it over I plan to show the working motor only after I patent it.
I already gave out enough information about it if someone decides to use the SLING METHOD of making it. It's not as simple as it looks to be as anyone attempting to replicate it will find out.
But you will see the light after you play with it a while.
Hi Tom,
Any success with the setup, or just another dead end? If success, are you already on the patenting route, or was laziness the king? :)
magnetman12003
Quote from: Airstriker on June 22, 2020, 03:49:47 PM
Hi Tom,
I did not patent it yet as I have found a better way to construct it without resorting to a sling arrangement as I described before. I am waiting on some more parts I ordered
  I will never give up on this idea.   A 45 degree inclined magnet and a single magnet bearing (by repelling) downwards with gravity on the 45 magnet is the way to go.  Construct such a motor using 4 of each magnets in a circular format and all will work out after a lot of thought on magnet placement.
Tom
ayeaye
Quote from: magnetman12003 on June 27, 2020, 07:21:59 PM
Interesting that it works, as you say it does.
Then, i think it may also be possible to make the 45 degree magnets stationary, and make only the ring magnet to rotate. The magnet bearings can also be used the same as in your motor. Kind of like you put your motor upside down. Then the 45 degree magnets don't move, are not on a floating ring magnet, and can be much heavier and stronger. That may add power.
