All Permanent Magnet Motor
Started by magnetman12003, March 28, 2020, 03:43:49 PM
synchro1
Longest spinning: The flywheel inertia would store like a battery and grow very powerful over time; A group could be tapped sequentially to supply kilowatts!
This kind of overhead magnet bearing would allow Tom's spinner to travel a thousand times faster; Perhaps guided by a sewing needle and garnet bearing.
Airstriker
Quote from: magnetman12003 on April 09, 2020, 01:14:50 PM
Number 3 with the plastic tubes extending about 1/2 of the way under the top section of the
45 degree angle.  Yes this sounds funny but it works out without the magnets jumping out of the tubes
South Pole of the rod magnet is drawn downward by the Larger North Pole Force of the ceramic magnet.
Gorrila Epoxy holds all ln place.  Rod magnets are 3/8 inch in diameter and  2 3/4 long each.  Need 2 for one 45 degree angle.
Block magnets are 3/8 thick, 1 3/4 long and 3/4 widh.
Name the motor. ""ROTOR FLOATER""  because not only the large top ceramic magnet floats but so do the rod magnets inside the plastic tubes. The ends of the tube are epoxy sealed just to make sure they don't come out while the motor is spinning.
Ok so something like in the picture below?
Just wondering... Is the upper ring magnet really needed? Have you tried it without it?
BTW, we actually still haven't seen the motor operational ;) Will you make some video?
And somebody please stop the troll synchro1 ;/ No moderators here?
synchro1
@Airstriker,
"And somebody please stop the troll synchro1 ;/ No moderators here?"
Are you suggesting that I'm somehow unfit to participate in this thread discussion? On what grounds? My innovations already improved the motor a thousand times.
I am offended by your bossy, overbearing attitude with Tom, ordering him to produce videos on demand. I find it objectionable. You should act more politely with him. Try the please word for a change.
Airstriker
Quote from: synchro1 on April 09, 2020, 06:28:27 PM
@Airstriker,
Dude who cares about your improvements when we don't know the basic design yet! Thanks to people like you the threads here have like 200 pages and there is maybe like 10 on the subject on them. What's the point synchro1? And you just made me write one of such posts! ;/
Let's find out the basics first, know that it's running, replicate, and then do all your crazy improvements. Be my guest. And if I ever offended here anobody that would be only you mate. Just please don't answer this message - I go to ignore mode with you. Sorry. And yes, I have seen your "Tut Tut pirate" message before you have deleted it. Seriously dude?!
synchro1
Quote from: Airstriker on April 09, 2020, 07:12:22 PM
@Airstriker,
You took a cheap shot then threatened to call the cops; Then you scored a pile on from the "Marshall"! You're just another Jackel debunker in sheep's clothing. You're out to replicate a failure in the end with the Holmes.
You are among the last people I would select to deliver a working replication. Once the principle is understood, anything will work. Your over labored attention to irrelevant detail is a dead end.
