All Permanent Magnet Motor
Started by magnetman12003, March 28, 2020, 03:43:49 PM
synchro1
Theory of propulsion: (Vector Reflection) Positioning a magnet sideways between the tube magnet stack and the ferrite ring would draw the ring to it like a "V" gate would attract movement. The "V" gate produces a "Panthom V" gate reflected in the opposite pole field of the top ring and the lower stationary ring acts as a parallel magnet and draws the top ring around.
skywatcher
Quote from: synchro1 on April 10, 2020, 04:34:41 AM
Why should anything move here ?  Everything tries to move from higher to lower energy potential, but there is no such potential gradient in this setup, so nothing will move at all. It doesn't matter which angular position the rotor has in respect to the stator, because the stator (ring magnet) is perfectly symmetrical so why should anything rotate ?
synchro1
Quote from: skywatcher on April 10, 2020, 08:10:41 AM
It's either spinning on its own or not. If so we need to supply a reason. A shot in the dark.
Any additional theories about the propulsion welcomed.
synchro1
Let's say we attach 4 neo cube magnets to the top ring in attraction. Would the distance between a ring in opposition increase? We are adding power to the repulsion field so the rings should separate more.
This brings us to the question of a tapering distance! I wonder if magnetman12003 has any ideas on how it works?
magnetman12003
This is a illustration of my setup with the 6 inch plastic tube correctly positioned.  The neo rod magnets are Shown in place. Clockwise rotation indicated by pointing the aluminum frame work in that direction.  A very powerful attraction downward force is delivered by the ceramic ring magnet below it. If that's not enough the repelling of the block magnet also pushes the rod magnet downwards.  South underside of block magnet -South rod magnet end - North is the ceramic magnets topside
