Alternative Partnered Output Coils and Free Energy
Started by Raycathode, April 03, 2020, 12:14:05 PM
WhatIsIt
Quote from: lancaIV on April 08, 2020, 04:29:34 PM
But it is important to listen to their serious scientifical arguments !
They do not say/declare that they know  about the working principle !
Everything around us is spinning so fast and with so much energy,
that only Moron can say that you can not grab a piece of that power!
Tell me that I am wrong and become same Moron as they are!
Quote from: WhatIsIt on April 08, 2020, 04:47:08 PM
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=adolf+zielinski&IN=&CPC=&IC=&Submit=Search
Some improvement possibilities ! Small to unconventional big !
"moron" is relatively new in use : Etymology[edit]Coined in 1910 by psychologist Henry H. Goddard, from Ancient Greek μωρός (mōrós, "foolish, dull").
dull can ever be also positiv : not to react to lower arguments
foolish : sometimes humans "in (self) love : and to reality blind " makes foolish things/treats
You have ever to know about the motivation from the "swearword"-user and to ask yourself if this is worth to draw the sword or only "cough parvenu"
nelsonrochaa
Quote from: AlienGrey on April 07, 2020, 11:47:09 AM
Hi Nelson, Yes that would be realy good, I will do what I can to replicate the the device if thats ok
Many thank AG
Hi AG ,
promised is due ;  here the diagram of the circuit that i share in the videos .
I have no way of measuring coil inductance. In this way I measure their resistance.
The values of choke are to each coil .  Maybe you need made some adjustments if values in coils are different , but should no be hard do that .
To find the best R1 Value you could use a variable resistor .
Best rewards
Nelson Rocha
https://idoorway.mirtesen.ru/blog/43208208685/Vizualizatsiya-strukturyi-magnitnogo-polya-Zemli-(efira)-rassmat?nr=1&utm_referrer=mirtesen.ru
Temperature and electricity
"Temperature is the lowest form of electricity" Victor Schauberger
What do the words of the Great mean to us? What was the point he put into them? What experiments did Victor Schauberger conduct to make such a conclusion? I thought about these words for a long time, they were, for me, like a "lighthouse", a "slogan" along with the "slogans" of other Great people.To begin with, I decided to prove by experiment, a simple experiment, the equivalence, the identity of "temperature" and "electricity". And I set the experience, which proved that this temperature is electricity only an octave less. "an octave less" is like the note "la" is different from the next note "la" but which is above.Pour the magnetic fluid onto the magnet and tell the magnet the temperature, in absolutely any way. Magnetic fluid is excited, as we considered in other experiments to determine the essence of the magnetic field.Now we will excite the magnetic fluid through electricity, but so weak as close as possible to the "transition point" to the next octave. We put on the magnet on which the magnetic fluid is poured a coil and start a current of 1 W on it. It is desirable to make a bifilar coil in order to synchronize the forces of attraction and repulsion between the wires in order to obtain a "pure" geometry devoid of Oersted perturbations, i.e. repulsive and attractive forces near lying wires. When excited, the magnetic fluid behaves identically, i.e. in the same way as it behaves when excited by temperature alone! The geometry is identical, i.e. 100% identical! My next experience was to find out the temperature limit, or say the highest temperature point after which the behavior of the liquid becomes "the same" as from the excitation by electricity. I did so. I heated the magnet slowly, the higher the temperature of the magnet, the faster the cones came into rotation, forming "slowed down" ether vortices, which appear IMMEDIATELY from excitation by current, as if bypassing the "temperature stage of motion". This temperature turned out to be equal to the boiling point of water, i.e. 100 degrees. Thus, 100 degrees is the equivalent of 1 W of constant electricity, but another octave. But is 100 degrees Celsius the temperature limit? If there is a lower temperature limit equal to "-3.73 W", i.e. -273 degrees, then its upper limit must exist ... and therefore there must be an upper limit of electricity ... But why " the equivalent of "does not start immediately, but in the already existing one? Why does the" lowest form of electricity "temperature and electricity exist at the same time? What should this geometry look like, this system, in which the temperature transforms into electricity, but continues to rise in its degrees? Does this mean that there is also "negative electricity" that the Great Tesla spoke of? Yes it does. But what place does all this occupy in our worldview? How is our body temperature equal to 36.6 degrees connected with what we call What are 366 days a year and 366 degrees in a circle? at which temperature turns into electricity, but continuing to rise in its degrees? Does this mean that there is also "negative electricity" that the Great Tesla spoke about? Yes it does. But what place does all this occupy in our worldview? How is our body temperature equal to 36.6 degrees connected with what we call "366 days a year" and "366 degrees in a circle"? at which temperature turns into electricity, but continuing to rise in its degrees? Does this mean that there is also "negative electricity" that the Great Tesla spoke about? Yes it does. But what place does all this occupy in our worldview? How is our body temperature equal to 36.6 degrees connected with what we call "366 days a year" and "366 degrees in a circle"?
1 hour = 3600 seconds
366 days as maximum (29.February) and 365,25 days average because each earth-day has 23 hours and 58 minutes
366 days is base from today cristian  julian-gregorian calendarium , not based by Nature but by humans
arbitrary fixation !
Alternatively : 9 months calendarium Maya and other
https://instituteinventors.com/profile-of-michael/  What is temperature ?
Physics: Michael aged 17, discovered What is temperature? & Orbiting Electron Frequency Concept to explain precise nature of Heat Thermodynamics, Radiation, Conduction, Adiabatics, Nuclear Energy, Boyles & Charles Laws. Temperature is measured in Gigacycles/sec),OEF Laws Expose Einstein's Genius Absurd Hoax SciFi Space/Time Warp Theories & Quantum/Fusion Physicist frauds – defineheat.com
Institute of Inventors19-21 Fosse Way, Ealing, London W13 0BZTel: 020 8998 6372, 020 8998 4372 Mob: 078 76 75 66 62Phone any day – 8 to 8 p.m. email: mikinvented@aol.com (mikinvent@aol.com)
https://chem.libretexts.org/Bookshelves/General_Chemistry/Map%3A_A_Molecular_Approach_(Tro)/05%3A_Gases/5.03%3A_The_Simple_Gas_Laws-_Boyle%E2%80%99s_Law%2C_Charles%E2%80%99s_Law_and_Avogadro%E2%80%99s_Law
Electricity : https://translate.google.com/translate?hl=de&sl=de&tl=en&u=http%3A%2F%2Fwww.chemgapedia.de%2Fvsengine%2Fglossary%2Fde%2Felektronengas.glos.html
to :
                                                      Hinge model                Molecular Orbital Theory
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3601309&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
The invention is based on the object of developing a device which has a very high energy density and is economical to manufacture.
This object was achieved by the invention of an electromagnetic solid-state battery.
The invention is based on the phenomenon that certain magnetic materials spontaneously release magnetic energy under very specific conditions. This phenomenon that I discovered is called the Zielinski effect. This spontaneously released magnetic energy is very considerable and is of the order of magnitude that has only been known so far in nuclear fission.
I also discovered that with certain materials, this spontaneous magnetic energy release can be brought about in a constant and controlled manner if these materials are resonated in a certain way. It turned out that the magnetic energy released is much larger than the energy needed to keep the resonance going once this resonance has been achieved.
The above property has certain materials that have a crystalline molecular structure. Atoms are released from the crystalline molecular lattice by a certain resonance, which causes the release of magnetic energy. If this magnetic energy is not dissipated, this atom detached from its lattice is captured again in another lattice. However, this magnetic energy can be captured, conducted from <N = 3> and converted into electrical energy. The crystalline structure of the material is transformed into an amorphous structure. Since the energy output per atom that is detached from the crystalline lattice is very large, but on the other hand this atomic process is very slow, an electrical energy source with a very high energy density and service life can be constructed using the physical properties and processes mentioned above.
https://www.toppr.com/ask/question/the-orbital-frequency-of-an-electron-in-the-hydrogen-atom-is-proportional-to/
For nuclear - quantum mechanics- devices we need instead Volt calculation                eV units ( ancient dyn,erg)  understandings
https://www.google.com/search?q=elektronenvolt&rlz=1C1AVFC_enPT797PT797&oq=elektronenvolt&aqs=chrome..69i57.7261j0j7&sourceid=chrome&ie=UTF-8
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.wikipedia.org%2Fwiki%2FElektronenvolt
https://en.wikipedia.org/wiki/Electronvolt
seychelles
