Alternative Partnered Output Coils and Free Energy
Started by Raycathode, April 03, 2020, 12:14:05 PM
DavidWolff
Quote from: seychelles on April 11, 2020, 06:06:45 AM
JUST SHARING THIS BRILLIANT INVENTION.
Hi Mr Desmond an interesting Idea have you made such a device ?
how did you wind the coils ? only wouldn't you have to wind it on round toroids and tune each one
to it's own note that was in tune with a pacific frequency ? I'm not too hot on music but wouldn't
each note have to be in tune ? ie not out of tune if you see where I'm going with this.
Any way I don't want to wind you up or steel your idea but it is a brilliant idea you have if I can help.
Regards Dave
seychelles
YO ALL COILS ARE WOUND AS PER PARTNERED COILS AND STRINGS ARE
TUNED TO RESONATE WITH THE INPUT COIL FREQUENCY.
AlienGrey
Hi Nelson Thanks again for your help your technique and help.
Sorry to take a while getting back to you but everything is on lock down here so getting
Second hand or new components is a real problem at the moment.
Fortunately I managed to strip down an old power supply and rewind some of the inductors.
To cut a long story short i have built a 'birds nest' device that works pretty well
the incandescent bulbs are also a problem at the moment but I managed to use a couple of
LEDs with a 150 ohm in parallel with it and a 10 ohm in series which sort of has the same effect
as a pigmy type mini wire ended bulb intensity replacement.
For learning and experiments.
Thanks again
AG
www.overunity.com
What is "overunity" ? A dream ? A misinterpretation ? An impossibility ? A real conventional possibility ? By all given physical laws not denied ?
examples about not physical "overunity" showing :
The Flynn brothers Parallel Path development company now named https://www.qmpower.com/
up to less 80% power consume = 500% improvement
compared to other actual industrial selled 15-20% efficiency induction fan motors
https://www.energydepot.com/RPUcom/library/MISC003.asp
15 % - 20 % x up to 500% improvements = <= 100 % technical efficiency
NO OVERUNITY !
https://www.rapidtables.com/calc/electric/watt-to-va-calculator.html
WATT to VA    ( what is V and how called : a. Voltage b. tension c. electric energy )
Watts to VA calculationThe apparent power S in volt-amps (VA) is equal to the real power P in watts (W), divided by the power factor PF:
S(VA) =  P(W) / PF
we give in the calculator in :
Watt : 25
Power Factor : 0,2
and we get as VA : 125
"125 VA = 25 Watt " : Attention we use conventional day by day used EE  formula , now conditionizing " 125 VA x PF 0,2 = 25 Watt"
POWER FACTOR ?
https://www.engineeringtoolbox.com/power-factor-electrical-motor-d_654.html
The power factor defined by IEEE and IEC is the ratio between the applied active (true) power - and the apparent power, and can in general be expressed as:
        PF = P / S
where
PF = power factor
P = active (true or real) power (Watts)
S = apparent power (VA, volts amps)
A low power factor is the result of inductive loads such as transformers and electric motors. Unlike resistance loads creating heat by consuming kilowatts, inductive loads require a current flow to create magnetic fields to produce the desired work.
Power factor is an important measurement in electrical AC systems
 Typical Motor Power Factors ( cos Phi )  NO        LOAD                0,15 - 0,2
                                                         1/4 -1/1 LOAD                0,5 -  0.9
         0,9 / 0,15 =       up to   6 times 0r 600% POWER FACTOR improvement ,but NO OVERUNITY !
        motor nominal power rating,nominal rpm
        S(VA) =  P(W) / PF                                         NO LOAD POWER FACTOR 0,15 -0,2                      NO         LOAD WATT CONSUME : ?
        S(VA) = P(W) / PF                                          1/4 - 1/1 POWER FACTOR  0,5 - 0,9                       1/4- 1/1 LOAD WATT CONSUME : ?
                                                     https://www.energy.gov/sites/prod/files/2014/04/f15/10097517.pdf
                                                            page 6,equitation 5 FORMULA SLIP LOAD CALCULATION
                                        synchronous speed    1800 rpm, full load speed 1750 rpm, measured speed 1770 rpm
                                         all speedings in the +- 2,5% difference range : but only 60% from rated horsepower output
When here not is to find an amplification effect what and how is an "overunity operator/process" ?
A.overunity is the difference from rated device output to device input : nominal output ≥ input
B. This "overunity effect" = process result is   a. exogen/external absorption b. indogen/internal transformation
Zenon de/from/aus Kition ,300 ante Criste
Pythagoras de/from/von Samos ,500 ante Criste
Iesus de/from/von Belem, inte/r Criste
We de/from/von " everywhere" , poste Criste
spatiare spaciare spacio Espace SPACE RAUM + ZEIT-TIME + TEMPO CONDITIO = ambulare
RAUMZEITREISE : DIE REISE DURCH UND MIT ZEIT UND/ODER RAUM
                                 DIE REISE DURSH UND MIT RAUM UND/ODER ZEIT
                                 DIE REISE DURCH RAUM (differ : DIE RISE DURCH DEN RAUM,defined)
                                DIE REISE DURCH ZEIT     (differ:  DIE REISE DURCH DIE ZEIT,defined,)
pius pio prius propius proprietare inprietare ex(-pro-) prietare propius property exproberty inproberty
Minimum = ]   [        ex ",Mengenlehre= set theory "   = non tangens ergo a. non exsistere b. non existere ? c. exire ?
                     ]    [       "  Nihil  " , abstract logical translation in arithmetical language  = Leere RAUM Leere ZEIT
                               Beziehungs-/Verhaltens-      Forschung/-Analyse/-Lehre :
                               kinematische Relativistik      relativistische Kinematik
Maximum 2020(p.C.) : Planet/Moon/-s,Solar/Star-system/-s,
1 Galaxy,10,100,1000,10000,....... 1 000 000 000 +X Galaxien
                             ETERNAL     KOSMOS               TOTUM-OMNES
About : small Small SMALL        great Great GREAT      huge Huge HUGE
RAUM ROAM         R.A.M. = RANDOM ACCESS MEMORY   R.O..M. = RANDOM OPERATION MEMORY
                                 together :   R.O.A.M. and tempo : speed + velocity : FLOPS -scale
The 2020 STOA about 2020 HUMAN KIND SHOA
fixare pendere currere cessare cedere tangere  passare ambulare
hope,fear,wish
pressure: im-/ex-/de- pressure
free will/enforced
VOTIV  MOTIV  votare/vote motere/Motor
mutare : CHANGE  : RISC or CHANCE
genere/generare Genus  Generalitas General  Geral
struere construere destruere
LIBERALITAS : constructive destruction
                           destructive construction
Ovid : Meta Morphosen  The ( Ovids = my/ from us : his ) REFLEX REVIEW  REVISION
       Meta morpeus ~ materia scan by c.n.c to C.A.D.  Meta fisica ~ C.A.D. with C.N.C. to materia
     POINT BEAM DISTANCE LINE 0-1-X-XY -XYZ CO-ORDINATION 0- -1  - -X - X/-Y - -X/-Y/-Z
     REALISMUs SURREALISMUS CONCRETIVIMUS  ABSTRAHISMUS
     VERTICAL HORIZONTAL FIELD AREA 1D 2D 3D 4D 5D .......
      Giving form-at  : block to plastique  f.e. Michelangelo "David"
      Taking matter from block
      Giving form-at,CONSTRUCTION  : sand at beach to " sand castle"
      Taking sand-korn his freedome degree : bonding,fixing,colare~ glueing
       DESTRUCTION by water FLUT after  EBBE : TIDE/-S,AMPLITUDE
       podere possere PODER POWER GEWALT  :
       EINBEHALT    IN- DIVISION IN-DIVIDUUM            TEILUNG DIVISION DIVIDUUM
     sentire sense sensitiv
     WITH NO(-N) SENSE  NONSENSE
    GERAL 2020 STOA + 2020 IMMANUEL KANTs' "CATEGORIC IMPERATIVE"=VOCATIV ! : APPLY IT !
( ramset,Chet  >:( : BE THAT CHANGE !  8) WITH STOICAL CALM ?  ;) AND BY HARMONY ?! :) )
All-(w-)right ?   ALL WRONG ? ALL CHANGING ?
R.A.M.,SET THE POINT ?
.  : R.O.M. : Yes,that is a POINT,but only one undefined  fix, now the END-Point after this KATA-Monolog  :      .
