Kundel Torque Amplifier
Started by synchro1, July 15, 2020, 02:50:24 AM
Hello synchro1,
related # Reply 6
"  Kundel claims his generator to be close to 1700 times overunity. It's easy to see why if you read his patent and examine his generator "
could you give me please the link to this "statement" !?
https://patents.google.com/patent/US7400069B2/en
Also referring Stephen Kundel this
Assistant Professor, Mechanical Engineering, Rajalakshmi Institute of Technology, Chennai
https://www.researchgate.net/publication/333672994_Experimental_Design_and_Optimization_of_Free_Energy_Generator_by_using_Neodymium_Magnets
did 2017 some generator experiments and calculations !
synchro1
compare the positions of the diametric; the difference is the throw;
synchro1
see how the arc magnets are mounted on spacers that match the magnet bushings, and the diametric is fattened and shortened in length and the cross tee is cut short on each end.
synchro1
We can shorten the radius of the piston arm and increase the magnet area with arcs. Neo discs may add power to the rotor substituted for the arc. This design could be miniaturized with precision spring pawl ratchet cog and latching magnet springs to run a pocket watch.
synchro1
An even better slider shape magnet. This piston magnet will seat squarely in the PVC arm. The outer circumference of this arc segment needs to match the I.D. of the rotor arc magnet.
