Kundel Torque Amplifier
Started by synchro1, July 15, 2020, 02:50:24 AM
synchro1
                                                      New Kundel Gear
A large diametric tube would shuttle a piston of two connected semicircle axial half's back and forth as the tube was twisted:
synchro1
New type of gear; Two large diameter diametrically magnetized tube segments each with two connected reverse axial polarized semi circle pistons!
synchro1
A clearer picture of the gear: Tightening this gear will cause less interaction and allow a smaller radius for the rotor arm.
synchro1
The rotor arm has been factored out:
synchro1
The miniature rotor and semicircle slider are housed inside a large ceramic mounted pillow bearing. The connection between the side car tube Kundels and the rotor bearing are not shown:
The construction of the "Tube Kundel Piston" and the "Semi disc siamese arc slider" are identical to each other! #17 above.
