"Magnet shear to direct pull work ratio"
Started by Floor, July 16, 2020, 08:59:39 AM
Floor
@ Lota
Did you take any measurements of the mechanical work done as inputs and
out puts ?
    floor
lota
Hello
no. I only did a trial setup.
Greeting
Lota
Floor
@Lota
OK / Thanks...
With only around 8.3%    EDIT 12/08/21 that is 9.02275 % O.U., friction losses need
to be kept low.
                    But
a flywheel could carry the output energy past the input energy in a
single unit ?
  best wishes
              floor
    P.S. I moved the link to the video you posted to ...
    https://overunity.com/18876/o-u-magnet-force-shielding-2-and-so-on/msg561932/#msg561932
Edit / addendum  1/3/2022
These measurement sets were not done with my usual
degree of rigor.
          also
I think the  entire procedure should be redone with neo. magnets
of a cube shape.
Floor
Edit / addendum  1/6/2022
Earlier on in this presentation I though I could shortcut (I was fatigued) and
pull out an average force over the displacements by just picking the value in
the mid range of the forces on the charts.  Big mistake.  A later, following through
with the complete calcs. revealed that the final output is much smaller than I had
originally presented.  Bummer. My blunder, my apologies.
I still think the entire procedure should be redone with neo. magnets
of a cube shape.
"It is intuitive that magnetism holds secrets!" - Ramset
                         floor
synchro1
1.3 Watts in 3.4 Watts out! OU COP of 2.42!
