Another failed project
Started by nix85, August 31, 2020, 08:57:01 AM
sm0ky2
35 yrs of magnetics, as it pertains to overunity research:
I've found that for energy to be "produced"/ manifested / realized
The magnetic field interactions must compliment one another.
The forcing of magnetic repulsion or attraction is an inherent energy drain.
To explain what i mean in better terms, from the perspective of the stationary magnets:
If the rotating magnets are approaching, the interaction should be attractive
If the rotating magnets are departing, the interaction should be repulsive.
(complimentary)
"neutral" or null zones should be targeted towards the transition areas.
sticky points, cogging, etc. results from uncomplimentary interactions.
That's about as simple as i can make it.
If the magnets help each other energy can be infinite,
if they work against one another energy can be negative infinity.
SolarLab
Keep in mind "Electromagnetics" can be controlled - thus they can
truncate the magnetic process at will, unlike permanent magnets.
nix85
The claim that
"The magnetic field interactions must compliment one another.
The forcing of magnetic repulsion or attraction is an inherent energy drain."
is wrong. Altho i failed replicating Engel, there are many for whom this principle
worked. Apart for the already linked one from Pakistan above, to list a few.
Turn the volume down when opening the second and third video, they're loud.
https://www.youtube.com/watch?v=m0LjPc0lxfM
https://www.youtube.com/watch?v=2zI7gMv8qpw
https://www.youtube.com/watch?v=x_CFLL68aZQ
https://www.youtube.com/watch?v=c4FEba4kQb0
https://www.youtube.com/watch?v=-uZDk56Do-Q
https://www.youtube.com/watch?v=HtaRKd9rmj0
And along the similar lines recently published, also force-making/breaking the flux with large energy gain
https://www.youtube.com/watch?v=JU2JyE9h5o8
And then there is Loriga magnetic repulsion motor, simply periodically lifting and lowering the stator permanent magnet with big energy gain
https://www.youtube.com/watch?v=zg4mVFP209Y
And so on
""neutral" or null zones should be targeted towards the transition areas." Wrong. In all examples above, force-making/breaking the flux results in overunity. That quote is true for magnet-only motors only. And it is obvious and perfectly assumed that in magnet-only motors magnet should be attracted to a point, transition it neutrally and then be repelled (or at least not attracted) meaning no drag at transitional points, that is what bypassing sticky point means.
"sticky points, cogging, etc. results from uncomplimentary interactions."
You keep confusing the Engel and similar principles with magnet-only motors. They are very different. In Engel-like motors aka magnetic-coupling overunity motors, sticky points are a constant thing, yet overunity results. If what you say was true it could not happen. So that is true only for magnet-only motors. It is obvious and perfectly assumed that in magnet-only
motors rotor should be attracted on approach and repelled when leaving.
As i said, sticky points relate to magnet-only motors only and they are a story unto themselves.
There are many ways to overcome the sticky point many of which are shown in my perpetual
motion playlist. Clever combination of magnets, iron and geometry can bypass sticky point, that is about as
https://www.youtube.com/playlist?list=PLS6CmWwu5VGl5al_O94rmKNiuSZs7Loz1
And last claim
"If the magnets help each other energy can be infinite,
if they work against one another energy can be negative infinity."
is also wrong and does not hold for coupling-overunity or magnet-only motors. As i said, in coupling-overunity, forced making/breaking flux is used. In magnet-only motors various clever combinations of both magnetic attraction (to iron) and magnetic repulsion are used.
May those with eyes to see see.
Obviously electromagnetic fields can be controlled, many overunity devices rely on electromagnet manipulating the fields, neutralizing permanent magnets etc.
floodrod
I personally think this one is totally fake.  https://www.youtube.com/watch?v=-A9UGVTDeto
at 2:18 mark he drops the "supposed magnet" that looks like a tic-tac container all taped up.  It doesn't sound like a solid magnet to me.  It's about the right size for a battery to fit with a sensor (or reed) and an inductor.
Looks 100% bogus to me...
I can even see the lines where the tic-tac bottle top lid opens through the tape.
nix85
Tic-tac bottle looool. Funniest thing i've read today. And you even "see" it open.
If that was a tic-tac bottle it would have to be filled with sand or something to hit the table so hard when tipped over.
Secondly, if it was tic-tac bottle how come it is vibrating as magnets pass by at 2:50.
It is not a tic-tac bottle, it is a magnet and video is real.
As he says in the comments "The wheel and shaft is the old vcd player head."
