Dry land wave powered generator, working prototype
Started by burnit0017, September 12, 2020, 10:38:54 AM
burnit0017
https://youtu.be/JgotDI7XV-0
https://youtu.be/4Oj5fGAKXaE
Hi, I fabricated a machine I found on youtube.  I am using a wiper motor to drive the machine. I will replace the wiper motor with a 3 by 3 Neo and two coils to improve system efficiency. VOC about 80 volts AC. I did manual testing of PMA and was able to about 7 amps at 12 volt DC using a super cap bank as a load.  I use a variable PWM to greatly reduce The back emf at the PMA.
https://youtu.be/MY9224PYyR0
a.king21
The device should work, provided you are near the sea. The input energy is from sea waves and the output is a rotary movement used to power a conventional generator. It is not OU but a wave to electricity converter.
burnit0017
Hi, no sea waves required , input energy will be from 3 by 3 Neo and a small electric pulse. Making modifications at this time. I will post test results soon. Thanks for the input.
